[GRASS-dev] can't force a windows layout in wxGUI
Hi
I'm not able to force a windows layout.
I set up my windows sizes and placement, check "Save current window
layout as default" and "Suppres positioning..." in settings, then
"Save", but in a next wxGUI session my layout is not restored
That used to work in the past...
Maciek
Maciej Sieczka
www.sieczka.org
Hello GRASS devs,
Today I tried to compile grass6_devel fresh from svn and got this problem:
gcc -I/home/bobm/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/include -g -O2 -fPIC -DPACKAGE=\""grasslibs"\" -I/usr/local/include -DPACKAGE=\""grasslibs"\" -I/usr/include/ffmpeg -I/home/bobm/src/gis/grass6_devel/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/gsd_img_mpeg.o -c gsd_img_mpeg.c
In file included from gsd_img_mpeg.c:29:
/usr/include/ffmpeg/avformat.h:282: warning: ‘AVFrac’ is deprecated
gsd_img_mpeg.c: In function ‘gsd_close_mpeg’:
gsd_img_mpeg.c:439: error: incompatible type for argument 1 of ‘url_fclose’
make: *** [OBJ.x86_64-unknown-linux-gnu/gsd_img_mpeg.o] Error 1
It seems to be a problem with FFMPEG. What is FFMPEG used for anyways?
Bob
/usr/include/ffmpeg/avformat.h:282: warning: �AVFrac� is deprecated
gsd_img_mpeg.c: In function �gsd_close_mpeg�:
gsd_img_mpeg.c:439: error: incompatible type for argument 1 of �url_fclose�
At the bottom of lib/ogsf/gsd_img_mpeg.c, change the line:
  url_fclose(&oc->pb);
to:
  url_fclose(oc->pb);
This has been fixed in 7.0 in r35270, but not backported.
NVIZ uses it to save animations in video (AVI etc) files.
If you don't need that feature, you can use --without-ffmpeg to
disable the use of FFMPEG.
On Mon, Jan 12, 2009 at 7:36 AM, Glynn Clements
to:
       url_fclose(oc->pb);
Are you sure?
http://trac.osgeo.org/grass/changeset/35273
http://trac.osgeo.org/grass/changeset/35272
(5 days ago)
Bob, perhaps you need to update from SVN?
> to:
> url_fclose(oc->pb);
Are you sure?
My mistake. I assumed that he was having the problem the fix was meant
to address, but it's the opposite problem.
