[GRASS-dev] cause for bad colors in output from png driver
Glynn,
I finally isolated the cause of the color issue I’m having with the PNG driver.
It is the GRASS_TRUECOLOR setting.
If this is set to false, then the PNG looks fine, except that it uses a limited color pallet. If it is set to true, the PNG has black where it should be white and other issues.
GRASS_PNG_AUTO_WRITE=TRUE
export GRASS_PNG_AUTO_WRITE
GRASS_RENDER_IMMEDIATE=TRUE
export GRASS_RENDER_IMMEDIATE
GRASS_TRUECOLOR=TRUE
export GRASS_TRUECOLOR
export GRASS_PNGFILE
GRASS 6.3.cvs (spearfish60_test):~ > d.barscale tcolor=green
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file: /Users/cmbarton/map.png,
GRASS_WIDTH=640, GRASS_HEIGHT=480
WARNING: Color: can’t set color -256
This gives a black background to the barscale
GRASS 6.3.cvs (spearfish60_test):~ > d.legend elevation.10m
WARNING: Color: can’t set color -16843264
WARNING: Color: can’t set color -33686272
WARNING: Color: can’t set color -50529280
A lot more of these errors. This is what is locking up the wxPython overlay routine
If I set GRASS_TRUECOLOR=FALSE, I get no errors, d.barscale is correct, but of course the FP colors in d.legend do not display properly.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Michael Barton wrote:
I finally isolated the cause of the color issue I¹m having with the PNG
driver.
WARNING: Color: can't set color -256
WARNING: Color: can't set color -16843264
WARNING: Color: can't set color -33686272
WARNING: Color: can't set color -50529280
routine
Duh; this is related to the changes to support mmap()d files.
The framebuffer is always stored as B,G,R,A (the format used by 32-bpp
BMP files). This corresponds to 0xAARRGGBB on a little-endian system
and 0xBBGGRRAA on a big-endian system (e.g. Mac).
Externally (DRV_color, DRV_lookup_color), the alpha value is always
zero (0 = opaque, 255 = transparent), resulting in 0x00RRGGBB on x86
and 0xBBGGRR00 on Mac. But the valid range of colors is always 0 to
0x00FFFFFF inclusive.
Hence the error on Mac, and why I couldn't reproduce it on x86.
I'll change it to always use 0x00RRGGBB externally.
Thanks. This was a really baffling one.
Michael
driver.
routine
phone: 480-965-6213
fax: 480-965-7671
Glynn,
Just compiled the newest version from the CVS and this is solved. Thanks
very much for responding so quickly.
Michael
phone: 480-965-6213
fax: 480-965-7671
BMP files).
(answers my earlier r.what.color question)
This corresponds to 0xAARRGGBB on a little-endian system and
dumb question: are Intel Macs now little endian?
in gis.h I used:
typedef struct
    unsigned char r, g, b, a; /* red, green, blue, and alpha */
} RGBA_Color ;
typedef RGBA_Color RGB_Color;
/* RGBA_Color alpha presets */
#define RGBA_COLOR_OPAQUE 255
#define RGBA_COLOR_TRANSPARENT 0
#define RGBA_COLOR_NONE 0
Are the above alpha OPAQUE and TRANSPARENT values backwards? I had
pictured alpha as opacity, with OPAQUE being 100% and TRANSPARENT as 0%.
COLOR_NONE is used to indicate that the RGB array hasn't been filled.
(d.vect color=none)
Hamish
Intel Macs have always been little-endian. Only the PPC Macs are big-endian. So, giving "Mac" as an example of big-endian is now not sufficient. You need to say PPC Macs and Intel Macs (big/little).
:slight_smile:
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
Hamish:
Yup : Intel. Older PPC Macs were big endian.
Daniel.
-- Daniel Calvelo Aros
> BMP files).
Yes; the x86 is always little-endian; if you want to read big-endian
values, you have to do it in software.
in gis.h I used:
typedef struct
} RGBA_Color ;
(d.vect color=none)
There's no "right" answer; "alpha" can represent either opacity (0 =
transparent, 255 = opaque) or transparency (0 = opaque, 255 =
transparent).
The PNG driver uses transparency because all externally-specified
colours are opaque, and at that time, the integer colour number was
stored directly in the framebuffer. Transparent pixels can only arise
from erasing the framebuffer when GRASS_TRANSPARENT=TRUE, and (more
recently) with R_bitmap(). Note that R_bitmap() uses opacity.
When writing PPM/PGM files, the PGM file contains opacity values
(255-alpha). When writing PNG files, it calls png_set_invert_alpha(),
which causes the opacity values to be returned when reading.
I'm not sure which sense the 32-bit BMP format uses; the only
application I tested (gqview) simply ignores the alpha channel. If it
turns out that it's meant to be opacity, I'll need to invert the
internal format.
