[GRASS-dev] ccmath compilation error
lib/external/ccmath$ make
make lib
make[1]: Entering directory /home/yann/grass_dev/grass_yann/lib/external/ccmath' gcc -g -O2 -fPIC -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grasslibs"\" -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -I/home/yann/grass_dev/grass_yann/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/house.o -c house.c house.c: In function ‘house’: house.c:10:6: internal compiler error: in rewrite_use_nonlinear_expr, at tree-ssa-loop-ivopts.c:6215 Please submit a full bug report, with preprocessed source if appropriate. See <file:///usr/share/doc/gcc-4.7/README.Bugs> for instructions. Preprocessed source stored into /tmp/cc8wc4KR.out file, please attach this to your bugreport. make[1]: *** [OBJ.i686-pc-linux-gnu/house.o] Error 1 make[1]: Leaving directory /home/yann/grass_dev/grass_yann/lib/external/ccmath’
make: *** [default] Error 2
GCC version
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.7/lto-wrapper
Target: i686-linux-gnu
Configured with: …/src/configure -v --with-pkgversion=‘Ubuntu/Linaro 4.7.3-1ubuntu1’ --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs --enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.7 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --with-system-zlib --enable-objc-gc --enable-targets=all --with-cloog --enable-cloog-backend=ppl --disable-cloog-version-check --disable-ppl-version-check --enable-multiarch --disable-werror --with-arch-32=i686 --with-multilib-list=m32,m64,mx32 --with-tune=generic --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu --target=i686-linux-gnu
Thread model: posix
gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1)
make lib
`/home/yann/grass_dev/grass_yann/lib/external/ccmath'
gcc -g -O2 -fPIC
to your bugreport.
GCC version
gcc -v
COLLECT_GCC=gcc
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro
4.7.3-1ubuntu1' --with-bugurl=file:///usr/share/doc/gcc-4.7/README.Bugs
Thread model: posix
You posted that also earlier this year with this solution:
http://lists.osgeo.org/pipermail/grass-dev/2013-June/064468.html
"I have not had that problem after upgrading the machine..."
Perhaps try that again on your actual system?
Yes Markus, seems to be an Ubuntu 13.04 issue with both my nettop (Atom) pcs.
I am upgrading this one too in the hope to fix the same way.
make lib
GCC version
gcc -v
COLLECT_GCC=gcc
–enable-languages=c,c++,go,fortran,objc,obj-c++ --prefix=/usr
–program-suffix=-4.7 --enable-shared --enable-linker-build-id
–libexecdir=/usr/lib --without-included-gettext --enable-threads=posix
–with-gxx-include-dir=/usr/include/c++/4.7 --libdir=/usr/lib --enable-nls
–with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug
–enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin
–with-system-zlib --enable-objc-gc --enable-targets=all --with-cloog
–enable-cloog-backend=ppl --disable-cloog-version-check
–disable-ppl-version-check --enable-multiarch --disable-werror
–with-arch-32=i686 --with-multilib-list=m32,m64,mx32 --with-tune=generic
–enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu
–target=i686-linux-gnu
Thread model: posix
“I have not had that problem after upgrading the machine…”
This is only for ubuntu 13.04 34bit. Failing for a long time in launchpad builds[1]. I had filed a bug report[2] but no response yet.
[1] https://launchpadlibrarian.net/149593351/buildlog_ubuntu-raring-i386.grass70_7.0.0%2B0ubuntu2%2B29074~ubuntu13.04.1_FAILEDTOBUILD.txt.gz
[2] https://bugs.launchpad.net/ubuntu/+source/gcc-4.7/+bug/1201048
Unfortunately no response. Too bad for a gcc project.
grass-dev mailing list
grass-dev@lists.osgeo.org
Rashad
make lib
GCC version
gcc -v
COLLECT_GCC=gcc
Thread model: posix
Yes an upgrade to 13.10 does (again) solve the problem
Rashad
make lib
GCC version
gcc -v
COLLECT_GCC=gcc
Thread model: posix
