[GRASS-dev] Change in parser behavior?
Michael wrote:
We've tested on the command line and
in both GUI's and are baffled. I've sent the script to
Hamish to look at. It simply is ignoring data entered for
some arguments. I can find no rhyme or reason to it. I
thought it might be float data, but it doesn't seem to
matter if we change the types to integer or string. We get
the same lack of reading.
We've tried this on many versions of 6.5 from as far back
as 30 March to today, and on a Linux (Ubuntu) and Mac
system. Other scripts seem to work fine. I don't know if it
is the number of arguments or something more insidious.
I tried cutting out all arguments except one, named "R"
(R-factor for RUSLE), inserted an ...
echo "R=$GIS_OPT_R"
... and then ran the script on the command line
>> r.landscape.evol R=50
The terminal returned...
R=R=50
Go figure???
since a while ago the parser has not liked option names with
upper case characters. e.g. STREAM_DIR= in r.terraflow. I think
there was some posts about it, you were not the only person to
have trouble with addon scripts.
try changing to r= k= c= and I'm guessing it should work.
why? I've got no idea & it should probably be fixed before 6.4.0
as it (case in point) breaks back-compatibility even if none of
the standard GRASS modules use it. It is my guess that currently
r.terraflow will have issues because of it.
tabs, --help all work fine for me.
Hamish
