[GRASS-dev] Change the resolution in the output map
Hi coworkers
I'm working with grass62. I'm triying to create a raster map with finer
resolution from another with coarse resolution. The problem is the next:
- My coarse resolution map (input map) have 500 m of resolution, with
1000x1000 rows*cols. This information is the same as the current region.
- I want to create a finer resolution map (output map) with 100 m of
resolution, with 5000x5000 rows*cols.
- I have been trying with the next code:
  /* Adjust the region to new resolution */
  region.rows = nsubpixel*nrows;
  region.cols = nsubpixel*ncols;
  region.format = 0;
  region.compressed = 1;
  G_adjust_Cell_head( &region , 1 , 1 );
  G_set_window(&region);
  nsubpixel is 5 (500/100), and I'm writing a new header file with this
new information (region.rows=5000, region.cols=5000, region.ew_res=100,
region.ns_res=100) but when I read the new map, the next message error
is shows:
  WARNING: error reading null row 115
  ... a lot of times.
Thanks for your help.
Juan Diego Giraldo
Juan Diego Giraldo Osorio
Tel. 968 327 047
Departamento de Ingeniería Térmica y de Fluidos
Universidad Politécnica de Cartagena
España
  region.format = 0;
is shows:
  ... a lot of times.
If you want to work with different resolutions, you need to
continually switch between the two. Opening and reading the input map
must be done with the source region active, while opening, reading and
closing the output map must be done with the destination region
active.
See the r.resamp.interp and r.resamp.stats modules for examples.
