The following files currently differ between develbranch_6 and the
trunk, for no obvious reason:
doc/howto_release.txt
general/g.region/main.c
gui/tcltk/gis.m/gm.tcl
gui/tcltk/gis.m/gmlib.tcl
gui/tcltk/gis.m/mapcanvas.tcl
gui/tcltk/gis.m/runandoutput.tcl
lib/gis/gui.tcl
lib/gtcltk/gronsole.tcl
lib/proj/projlib.dox
scripts/d.split/d.split
scripts/d.split/description.html
vector/v.db.select/description.html
vector/v.db.select/main.c
vector/v.label.sa/labels.c
Can whoever made the changes check whether these should be merged?
You can use "svn diff" with two URLs if you don't have working copies
of both, e.g.:
svn diff \
https://svn.osgeo.org/grass/grass/trunk/general/g.region/main.c \
https://svn.osgeo.org/grass/grass/branches/develbranch_6/general/g.region/main.c
On Wed, May 21, 2008 at 10:09 AM, Glynn Clements
... above sync'ed.
No need to backport.
The following I didn't check (not my field):
lib/gis/gui.tcl
Hamish
May 21, 2008, 10:24am
3
and the trunk, for no obvious reason:
merged?
I have replaced d.split in grass7 with the d.frame.split script from grass-addons. It is much better but the options are not backwards compatible, so not backported to develbranch_6.
Hamish
