[GRASS-dev] Changes which may need to be merged
I've been doing some work on TclTk again, updating gronsole.tcl, gui.tcl,
and runandoutput.tcl.
My understanding is that I should be working on develbranch_6 for this. I'm
not clear whether these should go on to trunk or not since they're for the
TclTk gui.
If we are keeping the TclTk gui, they should be merged. I have working
copies of both trunk and develbranch_6. What do you recommend is the best
way to merge to trunk if that is what needs doing?
Michael
On 5/21/08 2:07 AM, "grass-dev-request@lists.osgeo.org"
<grass-dev-request@lists.osgeo.org> wrote:
Date: Wed, 21 May 2008 09:09:06 +0100
Subject: [GRASS-dev] Changes which may need to be merged
To: grass-dev@lists.osgeo.org
Message-ID: <18483.55458.558573.747611@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-ascii
The following files currently differ between develbranch_6 and the
trunk, for no obvious reason:
        doc/howto_release.txt
        general/g.region/main.c
        gui/tcltk/gis.m/gm.tcl
        gui/tcltk/gis.m/gmlib.tcl
        gui/tcltk/gis.m/mapcanvas.tcl
        gui/tcltk/gis.m/runandoutput.tcl
        lib/gis/gui.tcl
        lib/gtcltk/gronsole.tcl
        lib/proj/projlib.dox
        scripts/d.split/d.split
        scripts/d.split/description.html
        vector/v.db.select/description.html
        vector/v.db.select/main.c
        vector/v.label.sa/labels.c
Can whoever made the changes check whether these should be merged?
You can use "svn diff" with two URLs if you don't have working copies
of both, e.g.:
svn diff \
https://svn.osgeo.org/grass/grass/trunk/general/g.region/main.c \
https://svn.osgeo.org/grass/grass/branches/develbranch_6/general/g.region/main
.c
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
On Wed, May 21, 2008 at 5:28 PM, Michael Barton <michael.barton@asu.edu> wrote:
TclTk gui.
I see two ways:
- either always sync trunk
- or remove gis.m from trunk.
Everything else is confusing.
You mean always sync trunk AND develbranch_6 or sync trunk INSTEAD of
develbranch_6?
Michael
TclTk gui.
I see two ways:
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
I mean: keep trunk AND develbranch_6 sync'ed.
Or delete gis.m from trunk.
On Wed, May 21, 2008 at 8:08 PM, Michael Barton <michael.barton@asu.edu> wrote:
develbranch_6?
Michael
TclTk gui.
I see two ways:
phone: 480-965-6213
fax: 480-965-7671
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
I'm not sure what is going on with trunk at the moment. I don't mind
sync-ing with both. I just have to remember to do so. Can you merge in the
existing gis.m files that have changed? I don't know who made them all, but
I'm sure they should be merged. I'll sync both for any changes I make from
now on.
Michael
develbranch_6?
Michael
TclTk gui.
I see two ways:
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
Michael:
Can you merge in the existing gis.m files that have changed? I don't
know who made them all, but I'm sure they should be merged.
it is possible review change history either with "svn log <filename>" or through the web interface by clicking on the Rev column:
http://trac.osgeo.org/grass/browser/grass/trunk/gui/tcltk/gis.m
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/gui/tcltk/gis.m
Hamish
On Wed, May 21, 2008 at 8:20 PM, Michael Barton <michael.barton@asu.edu> wrote:
For obvious reasons trunk (7.0.svn) should not lag behind 6.4.svn. So
please keep it updated, too.
I don't mind
I am already overcommitted and cannot adopt the tcl part, too...
Someone, please...
I'll sync both for any changes I make from now on.
Michael
Good.
TclTk gui.
From the directory containing a working copy of the trunk, either:
svn merge -c 31350 https://svn.osgeo.org/grass/grass/branches/develbranch_6
svn merge -c 31332 https://svn.osgeo.org/grass/grass/branches/develbranch_6
or:
svn merge -r 31141:31350 https://svn.osgeo.org/grass/grass/branches/develbranch_6/gui/tcltk/gis.m gui/tcltk/gis.m
The former merges the two individual changes, the latter merges all
changes between the time the branch was made and the latest change.
But I'm thinking that it may be better to just remove gis.m from the
trunk. Once 7.x starts to diverge, maintaining two versions of gis.m
will become too much work. I would expect the wxPython GUI to be
stable by the time that 7.x is ready for everyday use.
Is there some way to see an online diff like you could with the old web cvs?
Michael
On 5/21/08 7:52 PM, "Hamish" <hamish_b@yahoo.com> wrote:
Michael:
.m
Hamish
phone: 480-965-6213
fax: 480-965-7671
On Thu, May 22, 2008 at 5:23 PM, Michael Barton <michael.barton@asu.edu> wrote:
Sure! Example:
http://trac.osgeo.org/grass/browser/grass/trunk/gui/tcltk/gis.m/thematic.tcl
In upper left corner, click:
    Last Change Revision Log
I have added this to
http://trac.osgeo.org/grass/wiki/HowToSVN#RevisitpreviousDiffs
