Hi everyone,
Quick question on the units used for the ouput of r.sun in mode 2 (daily
sums):
In the manual pages for r.sun, the following 'unit' is included in the
description:
The solar radiation maps for given day are computed integrating the relevant
irradiance between sunrise and sunset times for given day. The user can set
finer or coarser time step step used for all-day radiation calculations. A
default value of step is 0.5 hour. Larger steps (e.g. 1.0-2.0) can speed-up
calculations but produce less reliable results. The output units are in Wh
per squared meter per given day [Wh/(m*m)/day].
Is one to interpret this as "watt-hour per square meter per day" ?
This would seem a little odd, as the the unit 'watt-hour' is not an SI unit.
Hopefully I am reading this incorectly.
An alternative interpretation of these units (one which I hope to be the
correct one):
Wh.m-2.day-1 = "watts per square meter per day, as estimated at some fraction
of an hour" ?
Any thoughts would be appreciated,
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
sums):
description:
More odd (to me) is having (different) units of time in both the
numerator and denominator. I would have thought it more logical to
divide the result by 24 to give Watts per square metre [W/(m^2)].
> sums):
> description:
> relevant irradiance between sunrise and sunset times for given day. The
> user can set finer or coarser time step step used for all-day radiation
> calculations. A default value of step is 0.5 hour. Larger steps (e.g.
> 1.0-2.0) can speed-up calculations but produce less reliable results. The
> output units are in Wh per squared meter per given day [Wh/(m*m)/day].
> unit.
I need to check with some local experts, but judging from some recent tests -
the output from r.sun is comparible to that from a weather station, with
*hourly* averaged data in W/(m^2) which i think is analogous to the Wh/(m^2)
units that r.sun uses.
Dylan Beaudette
530.754.7341
