[GRASS-dev] clean_temp rewritten
I have (after a while of testing) submitted the new
lib/init/clean_temp.c code from Roberto Flor (ITC-irst).
The new code has better timing to remove old leftover
tmp files and also removed leftover subdirectories now
(in LOCATION/MAPSET/.tmp/).
Here some related offlist discussion excepts from the
test phase of the new version:
> > > if ( (pathlen=snprintf(buf,BUF_MAX,"%s/%s",pathname,cur_entry->d_name)) >= BUF_MAX)
> > > G_fatal_error("clean_temp: exceeded maximum pathname length %d, got %d, should'nt happen",BUF_MAX,pathlen);
> > Unfortunately:
> > 1. snprintf() is C99; not all systems have it.
> So far it is implemented a few times in GRASS:
> find . -type f -name "*.c" -exec grep -l snprintf {} \;
> ./raster3d/r3.in.ascii/main.c
> ./db/drivers/dbf/dbfexe.c
> ./raster/r.support/front/front.c
> ./raster/r.support/front/check.c
> ./raster/r.support/front/run.c
> ./raster/r.support/modhead/check_un.c
> ./raster/r.support/modhead/modhead.c
> ./raster/r.support/modhead/ask_format.c
> ./lib/db/sqlp/lex.yy.c
> ./lib/db/dbmi_client/select.c
> ./lib/gis/user_config.c
> ./lib/vector/dglib/examples/components.c
> Should this become at least a G_snprintf() wrapper
> in libgis?
I'm not sure.
If libc doesn't provide snprintf, the only options are to:
1. Implement it from scratch.
2. Write a wrapper which uses fprintf() to write the string to a
temporary file then reads the temporary file into the buffer.
3. Write a wrapper which discards the size argument and calls
vsprintf().
Option 1 is a fair amount of work (even extracting the code from libc
isn't simple). Option 2 is messy and option 3 creates the risk of
buffer overruns.
This issue has been discussed on the list in the past; IIRC, the
discussion was initiated by someone trying to compile GRASS on a
system which lacked snprintf(). I don't recall the conclusion.
This was also Glynn's suggestion in 2002 AFAIK:
http://grass.itc.it/pipermail/grass5/2002-April/005218.html
"Should I add a stub implementation to libgis?"
Here is the full thread:
http://grass.itc.it/pipermail/grass5/2002-April/thread.html#5117
"snprintf and other compile errors on IRIX"
IMHO, a quick solution to the problem is:
- make G_snprintf() a wrapper around snprintf()
- test therein if the system support snprintf(), if not, issue
  an error (or write an implementation, see below).
In this case we could identify systems with snprintf() being
unsupported using G_snprintf() and add extra tricks.
BTW, here a thread on mingW:
http://lists-archives.org/mingw-users/03714-mingw-snprintf-not-following-c99-standard.html
See here for a GPL'ed snprintf.c (suggested in above mingW thread):
http://www.ijs.si/software/snprintf/
a recent change makes i.find segfault.
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/imagery/i.find/main.c.diff?r1=2.4&r2=2.5
e.g. startup i.vpoints, click "vector" and you'll get a G_fatal_error():
ERROR: ask_gis_files: can't read tempfile
  [from i.vpoints/ask.c]
as i.find segfaulted didn't create the tempfile.
I've just added a return value test to the system("i.find") call in
i.vpoints (find.c), so you won't see that error after a cvs update.
it seems to break here:
  imagery/i.find/main.c line 111, in find()
while ((dp = readdir(dfd)) != NULL)
usage: (writes elements to a file)
  i.find [location] [mapset] [element] [output file]
e.g. list of spearfish raster maps:
G61> $GISBASE/etc/i.find spearfish60 PERMANENT cell /tmp/cellmaps.txt
Segmentation fault
thanks,
Hamish
Hello Hamish/Brad
I've fixed this now:
On Tue, 27 Jun 2006, Hamish wrote:
It was actually a bit before that around:
    G__file_name (dir, element, "", mapset);
    if ((dfd = opendir(dir)) == NULL)
        continue;
With the recent changes, dir was an uninitialised pointer at this point but G__file_name() was expecting a buffer into which it could copy its result.
Paul
On Tue, 27 Jun 2006 15:31:14 +0100 (BST)
Paul Kelly <paul-grass@stjohnspoint.co.uk> wrote:
Hello Hamish/Brad
> Hi,
        continue;
copy its result.
thanks, works.
One more problem, it now lists "." and ".." as filenames in the element
list. Obviously not maps..
Hamish
Hello Hamish
On Wed, 28 Jun 2006, Hamish wrote:
thanks, works.
Now it ignores hidden files (starting with a .). Does it work OK now? I notice the filenames aren't sorted as they were in the old version.
Paul
Paul:
Yes, in mild testing it seems to work fine.
sorting code in g.mlist?
thanks,
Hamish
