I got the CLI for wxgrass working again. You can type in any command (GRASS or shell).
Non-GRASS commands will simply be passed to the shell.
GRASS commands without arguments (e.g. g.region) will open their properties dialogs for non-display commands. d.* commands without arguments will add a layer to the GUI layer tree and open their respective properties dialog (e.g., d.rast).
GRASS commands with arguments (e.g., g.region rast=elevation.10m) will be passed to the GRASS command shell for processing. d.* commands with arguments (e.g., d.rast elevation.10m) will display their results in the currently selected map display. Multiple display commands separated by commas will send overlaying graphic results to the current map display (e.g., d.rast elevation.10m,d.vect roads color=red).
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
or shell).
(e.g., d.rast).
Michael
Great news. one small nitpick: wouldn't it be better to seperate commands with
a semi-colon instead of a comma? There are some commands which use the comma
to parse multiple entries.
cheers,
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
Good idea. I'll change it soon.
Michael
cheers,
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
I've been meaning to ask about wxgrass and CLI stuff - you're obviously working on a GUI psuedo-terminal for running commands the old-fashioned CLI way. I take it there is/will be no need for something like 'grass-xterm-wrapper', and any place that the TclTk GUI used that this pseudo terminal will work in wxgrass?
PS. did you ever get a chance to try my Terminal-enabled version of grass-xterm-wrapper? I've been lazy in committing it, so you'd have to dig it out of the email, or maybe I should just commit it anyways. It's in my binaries and I haven't heard of any problems yet...
Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
Hi William,
This should be unnecessary for a couple of reasons. One is that the new
wxgrass is native Mac, rather than xwindows. So stuff will run from the
regular terminal. The other is the desire to include a built in terminal
feature. This already exists in the TclTk version, but most people don't
notice or take advantage of it--probably because it's kind of on the 'busy'
side.
I guess I didn't but I'm not sure. I assumed that it was in the cvs. I've
probably buried your email somewhere. But it must be working somehow, since
I use the terminal for everything in the TclTk/x11 version of GRASS and
don't need to use the x11 terminal. I'm compiling from your *.app setup.
Michael
Michael
phone: 480-965-6213
fax: 480-965-7671
On Jun 8, 2007, at 11:26 AM, Michael Barton wrote:
Hi William,
side.
I kinda figured it wouldn't need some sort of external pseudo-terminal thing and be able to use its own. Just checking.
So, the create location by projection values opens in a Terminal? Then yes, you must have installed it into your source. When you update your CVS you probably always get a line "M lib/init/grass-xterm-wrapper".
I'll commit it then, to make it official.
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
