If I add a text layer to gis.m and click on it, I get the following error:
invalid command name "<<<<<<<"
while executing
"<<<<<<< dtext.tcl"
(procedure "GmDtext::options" line 3)
invoked from within
"GmDtext::options $id $opt"
("dtext" arm line 2)
invoked from within
"switch $type {
raster {
GmRaster::options $id $opt
vector {
GmVector::options $id $opt
(procedure "GmTree::select" line 14)
invoked from within
"GmTree::select $node"
(procedure "GmTree::selectn" line 7)
invoked from within
"GmTree::selectn .mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1 [string range [lindex [.mainframe.frame.pw1.f0.frame.pgs.fpage_1.sw.tree_1:cmd get..."
(command bound to event)
Can anyone confirm this error? I'm using Grass 6.3, cvs updated Novmeber 30th.
~ Eric.
Hmm, I didn't get any cvs errors during update. Should I blow away my cvs directory and do a fresh checkout instead?
~ Eric.
-----Original Message-----
To: Patton, Eric
Sent: 11/30/2006 10:18 AM
Subject: Re: [GRASS-dev] Clicking on a text layer in GIS manager gives tcl error
Hello,
On Thu, Nov 30, 2006 at 09:18:21AM -0500, Patton, Eric wrote:
error:
while executing
"<<<<<<< dtext.tcl"
Your sources have conflicts from a cvs update (the update failed and the
"<<<<<<<" are the lines where they were conflicts during cvs update).
You need to correct these (and the method depends on whether you have
local changes or not).
HTH
Thierry Laronde (Alceste) <tlaronde +AT+ polynum +dot+ com>
http://www.kergis.com/
Key fingerprint = 0FF7 E906 FBAF FE95 FD89 250D 52B1 AE95 6006 F40C
I tried this with a cvs version of 6.3 I compiled yesterday and cannot
duplicate it. The "<<<<<<<" command name looks very strange. I can't imagine
where this is coming from.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Michael,
As Thierry mentioned, deleting my grass6 directory and doing a fresh cvs checkout solved the problem.
BTW, text positioning works great! Thanks,
~ Eric.
To: Patton, Eric; grass-dev@grass.itc.it
Cc: grassuser@grass.itc.it
Sent: 11/30/2006 12:25 PM
Subject: Re: [GRASS-user] Clicking on a text layer in GIS manager gives tcl error
error:
imagine
Michael
phone: 480-965-6213
fax: 480-965-7671
On 11/30/06 11:14 AM, "Patton, Eric" <epatton@nrcan.gc.ca> wrote:
Michael,
Good. I'm happy that the text positioning works. I like it. Have you tried
the legend and scalebar mouse positioning too? Do they work for you?
Michael
phone: 480-965-6213
fax: 480-965-7671
> > while executing
> > "<<<<<<< dtext.tcl"
Conflicts are only reported once; if you miss them the first time, you
won't get any warning on subsequent updates.
Tip: update with:
cvs update 2>&1 | fgrep -v 'cvs server: Updating '
This makes it much easier to spot "useful" messages.
Although it's now moot, just deleting the file in question and
updating that file (or directory) will suffice.
Oh yes, those work great as well. The text, scale, and legend positioning tools is great for putting together diagrams, figures, etc. The more I can do in Grass, the less I have to rely on e.g. Inkscape to do the final text tweaking, which saves quite a bit of time.
~ Eric.
Sent: 11/30/2006 1:49 PM
Michael,
cvs
tried
Michael
phone: 480-965-6213
fax: 480-965-7671
On Thu, Nov 30, 2006 at 10:25:47AM -0700, we recorded a bogon-computron collision of the <michael.barton@asu.edu> flavor, containing:
This is a sign that the local copy of the file had been modified, and in a way
that conflicted with CVS --- CVS tags conflicts by delimiting the unresolvable
differences with lines beginning with "<<<<<<" so they can easily be found
and resolved by hand.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
