Hi Devs,
Suppose I want to export a vector layer to raster layer. I use a column in the attribute table to set the raster category values.
v\.to\.rast input=example output=example use="attr" attribute\_column="category"
If the column "category" has integer values the raster data type is CELL. It gets assigned a gradient color table, but one might prefer a discreet color table. Would this something to include as an option?
Reason I came across this is https://trac.osgeo.org/grass/ticket/3604#comment:3
Paulo
