[GRASS-dev] Color tables issues
I just had three issues with color table.
  1. First, I did not see anything when I showed the output of r.stats.zonal in map display:
r.stats.zonal base=basin_10K cover=aspect method=sum output=test
d.rast test
But the values were ok, so I realized I that the preset color table is wrong and I need to set my own.
  1. It worked, however, the color table pictures were not in the r.colors dialog. Note: I had freshly compiled trunk after make distclean (outside GRASS session).
So, I went to raster/r.colors and run make inside GRASS session. I got the color tables.
  1. In the meantime, I noticed that color tables thumbnails are in docs which is bad when some Linux distribution has the separate package for docs (recently noted on mailing list).
I think that 3) is mentioned in the related ticket. Not sure if 2) relates to recent changes in build GRASS session. 1) might be trivial to fix, not checked.
Vaclav
On Fri, Apr 4, 2014 at 4:29 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
1) First, I did not see anything when I showed the output of r.stats.zonal
in map display:
d.rast test
The current behaviour seems to be
        if (Rast_read_colors(covermap, "", &colors) > 0)
            Rast_write_colors(output, G_mapset(), &colors);
2) It worked, however, the color table pictures were not in the r.colors
GRASS session).
color tables.
Hopefully solved by Martin the other day:
http://trac.osgeo.org/grass/changeset/59820
http://trac.osgeo.org/grass/changeset/59821
3) In the meantime, I noticed that color tables thumbnails are in docs which
Perhaps we need them twice:
- in docs/html/colortables/ (as now)
- in GISBASE/etc/colortables/
(it is 160kb only)
