[GRASS-dev] command dialog notebook styles
I would like to inform you that you can now switch between different
command dialog styles in GRASS 7 (r52927). There are 4 styles, 3 of
them are new and they are providing platform native look. It should
solve the problem described in ticket #306 [1] (hidden tabs). Styles
can be changed in settings dialog - Appearance tab.
Two styles use wx.Notebook with top or left tabs. The third one which
uses wx.ListBook is not yet finished. The default style is the current
fancy green FlatNotebook.
It would be nice to add some icons to the tabs. So far I added only
icons to manual and options page to get idea how it could look like.
Unfortunately it is quite difficult to create icons which would
describe the tabs (required, optional, selection, ...). But except for
ListBook icons are not necessary. (Now icons are not used in fancy
green notebook because used style is not ready for icons.)
The advantage of the two basic styles is that they inherit system
colors (since they are native). So it is better for users with unusual
themes which are not much supported by wxPython.
Styles were tested on Ubuntu 10.04 (Gnome), information how styles
look like on Windows and Mac (including comparison to other
applications) is appreciated.
Please, share your ideas about style names, icons and styles itself.
If you know how, you can also try wxPython demo and do your own
experiments with various notebooks.
Note that this feature is experimental and even though it is change of
style some bugs which seem to be unrelated can appear.
Anna and Vaclav
(attachments)
Anna, those are great news!
This is, IMO, a much-needed improvement in GRASS interface. Quite a while ago I posted some thoughts on GUI and User Experience for GRASS, and native tabs do make a big difference.
Can this be applied to GIS manager as well?
best
Carlos
On Sun, Aug 26, 2012 at 2:02 PM, Anna Kratochvílová <kratochanna@gmail.com> wrote:
describe the tabs (required, optional, selection, …). But except for
Anna and Vaclav
grass-user mailing list
grass-user@lists.osgeo.org
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
Can’t stop the signal.
Hi Carlos,
On Sun, Aug 26, 2012 at 7:55 PM, Carlos Grohmann
I'm glad you like it.
Where can I find it?
Yes, but we must first understand how it should look like because
there are two level of tabs (top and bottom) so they probably should
look differently. Any suggestions are welcome.
Anna
best
Carlos
wrote:
Anna and Vaclav
- Digital Terrain Analysis | GIS | Remote Sensing -
________________
What about hiding display (fancy green) notebook with only one display
(one tab)? I guess that having only one map display is quite common
case, so in this case the notebook is not needed at all. Am I right?
And about notebook styles, it is not sure that it is possible to
change display names for all notebook styles (types). (Changing
display name is possible now by right click on the display tab).
Unfortunately, different features are available for different
notebooks, some features are not available for native notebooks, so we
cannot have just everything.
Vaclav
hi Anna,
is there any related wiki-page, where screenshots (i.e. windows, etc.) can
be uploaded?
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998097.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
be uploaded?
tested here in osgeo4w-wingrass7 in a win7-64bit-box.
only listleft works, in the other two no input is possible.
Helmut
http://osgeo-org.1560.n6.nabble.com/file/n4998104/notebookstyle_windows_listleft.png
http://osgeo-org.1560.n6.nabble.com/file/n4998104/notebookstyle_windows_basictop.png
http://osgeo-org.1560.n6.nabble.com/file/n4998104/notebookstyle_windows_basicleft.png
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998104.html
a basicleft turned up would be nice.
http://osgeo-org.1560.n6.nabble.com/file/n4998114/notebookstyle_windows_basicleft_turnedup.png
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998114.html
be uploaded?
That's bad. I am not able to test it. Are you able to switch the tabs?
Maybe it's some problem with refreshing. I tried to google some
windows specific problems with wx.Notebook but I haven't found
anything interesting.
The current fancy style works ok, is it right?
I will wait if the similar problem occurs on Mac to (Michael promised to test)
Thanks for testing,
Anna
Helmut
Helmut
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
One more question, all the tabs are empty? Command output and manual
tab are created separately so there could be some difference.
Anna
On Mon, Aug 27, 2012 at 6:52 PM, Anna Kratochvílová
be uploaded?
Thanks for testing,
Anna
Helmut
Helmut
best regards
Helmut
fancygreen => all tabs with content, manual ok
basicleft => all tabs with content, but no manual
the other two => all tabs empty, no manual
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998120.html
switching between tabs possible, but no effect.
saving the new configuration and restart of the gui doesn't help
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998121.html
a turned up basicleft would be nice.
http://osgeo-org.1560.n6.nabble.com/file/n4998123/notebookstyle_windows_basicleft_turnedup.png
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998123.html
manual should work now for the 'list left' style (but i hope we can
come up with some better name...)
I did some change (just a guess) so you can test again.
Anna
hi,
the manual works now.
the other two still empty
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998527.html
On Wed, Aug 29, 2012 at 10:52 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
Please test it again, I've just did some changes which (I hope) should help.
Anna
tested with osgeo4w-wingrass-7.0.svn-r52994
now all styles are working.
http://osgeo-org.1560.n6.nabble.com/file/n4998974/capture_001_31082012_083539.png
http://osgeo-org.1560.n6.nabble.com/file/n4998974/capture_002_31082012_083607.png
http://osgeo-org.1560.n6.nabble.com/file/n4998974/capture_003_31082012_083629.png
http://osgeo-org.1560.n6.nabble.com/file/n4998974/capture_004_31082012_083658.png
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998974.html
