[GRASS-dev] comparing r.cost and r.terracost
Same test region as before
North Carolina sample dataset
g.region rast=elev_state_500m@PERMANENT res=100
# gives about 28 million cells
v.to.rast nc_state@PERMANENT use=val val=500.0 out=cost --o
v.to.rast urbanarea@PERMANENT use=val val=1 out=urbanarea --o
r.cost in=cost start_rast=urbanarea out=dist_urban percent_memory=20 --o
grass7 r.cost
real 0m55.349s
user 0m53.360s
sys 0m1.797s
grass65 r.cost
real 26m35.166s
user 2m55.612s
sys 23m37.921s
r.terracost: check optimal tile size for 400MB memory (default setting; r.cost in grass7 used 135MB with 20% of maps in memory)
r.terracost in=cost start_rast=urbanarea out=dist_urban_terracost -i
TILESIZE: nc_spm_08 N=28064550 elements, M=419430400 bytes, optimal numtiles=1870
r.terracost numtiles=1870, intermediate data are stored on disk as r.cost does
real 25m13.593s
user 22m46.978s
sys 1m8.059s
r.terracost numtiles=1, all in memory (just fits into 400MB)
real 0m17.969s
user 0m17.276s
sys 0m0.500s
According to Laura Toma, when comparing r.cost with r.terracost, numtiles must be >1 for r.terracost in order to compare disk I/O algorithms [1]
With these test settings that intentionally reduced memory consumption in order to test disk I/O performance, r.terracost is not really faster than r.cost in grass65 and much slower than r.cost in grass7.
Markus M
[1] http://lists.osgeo.org/pipermail/grass-dev/2009-July/045157.html
