[GRASS-dev] compila grass on fedora31: configure: error: *** Unable to locate GDAL library.
Dear devs,
I have an issue when I try to configure ad compile grass.
At the moment I’m on Fedora 31. So I installed the default gdal (2.3.2) with:
sudo dnf install gdal gdal-devel gdal-libs
I executed locally gdalinfo on a tif and it provide the information of the raster and then I checked the installation paths with:
$ /usr/bin/gdal-config --version
2.3.2
$ /usr/bin/gdal-config --libs
-L/usr/lib64 -lgdal
$ /usr/bin/gdal-config --cflags
-I/usr/include/gdal
$ /usr/bin/gdal-config --datadir
/usr/share/gdal
So it seems to work, then my configure command is:
$ CFLAGS="-g -O1 -Wall -Wextra -Wundef -Wfloat-equal -Wpointer-arith -Wcast-align -Wstrict-prototypes -Wstrict-overflow=5 -Wwrite-strings -Wshadow -Werror-implicit-function-declaration -Waggregate-return -Wcast-qual -Wswitch-default -Wswitch-enum -Wconversion -Wunreachable-code -Winit-self -Wuninitialized -fno-common -fexceptions -fstack-protector -fmudflap -m64 -mtune=native" \
CXXFLAGS="-g -O1 -Wall" \
./configure \
--prefix=$HOME/.local \
--with-zstd \
--with-blas --with-blas-includes=/usr/include/atlas-x86_64-base/ \
--with-lapack --with-lapack-includes=/usr/include/atlas-x86_64-base/ \
--with-cxx \
--with-cairo \
--with-freetype \
--with-freetype-includes=/usr/include/freetype2 \
--with-geos \
--with-gdal=/usr/bin/gdal-config \
--with-gdal-includes=/usr/include/gdal \
--with-gdal-libs=/usr/lib64 \
--with-gdal-share=/usr/share/gdal \
--with-nls \
--with-netcdf \
--with-odbc \
--with-openmp \
--with-postgres \
--with-python=/usr/bin/python3-config \
--with-readline \
--with-proj \
--with-pthread \
--with-sqlite \
--with-wxwidgets=/usr/bin/wx-config
But I get the following error:
checking host system type... x86_64-pc-linux-gnu
checking for gcc... gcc
checking whether to use GDAL... yes
checking for gdal-config... /usr/bin/gdal-config
Do you understand why I still receive this error even if I specify all the paths of the gdal iclude/libs/share directories?
Any ideas on how to solve/fix this issue?
Thank you for your support.
Pietro
I had the same issue last week in an Ubuntu 18 box, both installing binaries and trying to compile grass. We had to remove everything, esp the official repo of qgis, install grass first from ubuntugis-unstable and then get an older qgis version. Some dependencies hell and conflicting versions, I guess…
Did you try installing from binaries? There’s already grass7.8.1 for f31: https://koji.fedoraproject.org/koji/buildinfo?buildID=1410936
Vero
El lun., 11 nov. 2019 a las 9:13, Pietro (<peter.zamb@gmail.com>) escribió:
Dear devs,
2.3.2
-L/usr/lib64 -lgdal
-I/usr/include/gdal
/usr/share/gdal
./configure \
--with-zstd \
--with-cxx \
--with-cairo \
--with-freetype \
--with-geos \
--with-nls \
--with-netcdf \
--with-odbc \
--with-openmp \
--with-postgres \
--with-readline \
--with-proj \
--with-pthread \
--with-sqlite \
Pietro
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Hi Pietro,
On Mon, Nov 11, 2019 at 1:13 PM Pietro <peter.zamb@gmail.com> wrote:
Dear devs,
At the moment I'm on Fedora 31. So I installed the default gdal (2.3.2) with:
`sudo dnf install gdal gdal-devel gdal-libs`
2.3.2
-L/usr/lib64 -lgdal
-I/usr/include/gdal
/usr/share/gdal
./configure \
    --with-zstd \
    --with-cxx \
    --with-cairo \
    --with-freetype \
    --with-geos \
^-- this is the only GDAL related line in my “configure” call (also Fedora).
^- these three I would not specify.
--with-nls \
--with-netcdf \
--with-odbc \
--with-openmp \
--with-postgres \
--with-readline \
--with-proj \
--with-pthread \
--with-sqlite \
checking host system type… x86_64-pc-linux-gnu
checking for gcc… gcc
checking whether to use GDAL… yes
checking for gdal-config… /usr/bin/gdal-config
- I would not specify them
- and: check the error in `config.log`
