[GRASS-dev] Compilation error in r.random.surface
while trying to generate Fedora and EPEL packages of 7.4.0 on COPR [1]
I came accross this issue:
/usr/bin/ld: Warning: size of symbol `Surface' changed from 8 in
OBJ.x86_64-redhat-linux-gnu/main.o to 768 in /usr/lib64/libgdal.so.1
/usr/bin/ld: OBJ.x86_64-redhat-linux-gnu/main.o: undefined reference
to symbol 'Surface'
/usr/lib64/libgdal.so.1: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[4]: *** [/builddir/build/BUILD/grass-7.4.0/dist.x86_64-redhat-linux-gnu/bin/r.random.surface]
Error 1
make[4]: Leaving directory
`/builddir/build/BUILD/grass-7.4.0/raster/r.random.surface'
Do we need to rename the "Surface" variable in the source code?
thanks,
[1] https://copr-be.cloud.fedoraproject.org/results/neteler/grass74/epel-7-x86_64/00706000-grass/build.log.gz
On Fri, Jan 26, 2018 at 1:56 PM, Markus Neteler <neteler@osgeo.org> wrote:
/usr/bin/ld: Warning: size of symbol Surface' changed from 8 in OBJ.x86_64-redhat-linux-gnu/main.o to 768 in /usr/lib64/libgdal.so.1 /usr/bin/ld: OBJ.x86_64-redhat-linux-gnu/main.o: undefined reference to symbol 'Surface' /usr/lib64/libgdal.so.1: error adding symbols: DSO missing from command line collect2: error: ld returned 1 exit status make[4]: *** [/builddir/build/BUILD/grass-7.4.0/dist.x86_64-redhat-linux-gnu/bin/r.random.surface] Error 1 make[4]: Leaving directory /builddir/build/BUILD/grass-7.4.0/raster/r.random.surface’
Do we need to rename the “Surface” variable in the source code?
That’s probably the easiest solution.
Markus M
thanks,
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Fri, Jan 26, 2018 at 11:24 PM, Markus Metz
to symbol 'Surface'
line
make[4]: ***
Error 1
That's probably the easiest solution.
Done in r72179 (trunk) and r72180 (relbranch74).
The updated EPEL7 rpm package is available here (above change included
as a patch in the SRPM):
https://copr.fedorainfracloud.org/coprs/neteler/grass74/
markusN
