I just compiled/installed grass78 on my computer (Ubuntu 18.04). After
installation and starting grass, it opens the opening window to select
the database/location/mapset. After that, the GUI does not launch.
Error message on the command line copied below.
Any idea how to solve this, or is this a bug that I should report?
Cheers, Paulo
GRASS 7.8.1dev (exdet):~ > 11:21:16: Debug: Adding duplicate image
handler for 'Windows bitmap file'
11:21:16: Debug: Adding duplicate image handler for 'Windows bitmap file'
File "/usr/local/grass78/grass78/gui/wxpython/wxgui.py", line 104, in OnInit
from lmgr.frame import GMFrame
File "/usr/local/grass78/grass78/gui/wxpython/lmgr/frame.py", line
51, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/usr/local/grass78/grass78/gui/wxpython/lmgr/layertree.py",
line 38, in <module>
from mapdisp.frame import MapFrame
File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/frame.py",
line 33, in <module>
from mapdisp.toolbars import MapToolbar, NvizIcons
File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/toolbars.py",
line 22, in <module>
from nviz.main import haveNviz
File "/usr/local/grass78/grass78/gui/wxpython/nviz/main.py", line
24, in <module>
from nviz import mapwindow
File "/usr/local/grass78/grass78/gui/wxpython/nviz/mapwindow.py",
line 42, in <module>
from nviz.workspace import NvizSettings
File "/usr/local/grass78/grass78/gui/wxpython/nviz/workspace.py",
line 23, in <module>
from nviz import wxnviz
File "/usr/local/grass78/grass78/gui/wxpython/nviz/wxnviz.py", line
52, in <module>
from grass.lib.raster3d import *
File "/usr/local/grass78/grass78/etc/python/grass/lib/raster3d.py",
line 1101, in <module>
Rast3d_fatal_error = _variadic_function(_func,_restype,_argtypes)
TypeError: __init__() missing 1 required positional argument: 'errcheck'
OnInit returned false, exiting...
On Sat, Sep 14, 2019 at 11:24 AM Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Hi Devs
installation and
just to be sure:
- you compiled yourself?
- you (of course) use Python 3?
Cheers, Paulo
51, in <module>
24, in <module>
52, in <module>
On Sun, Sep 22, 2019 at 6:57 PM Markus Neteler <neteler@osgeo.org> wrote:
Hi Paulo,
> Hi Devs
> installation and
just to be sure:
Yes
Yes, it used to work when I was working in a virtual environment
(following the instructions on the wiki). Now I have set Python 3 as
the default.
> Cheers, Paulo
> 51, in <module>
> 24, in <module>
> 52, in <module>
Does this problem persist after
make distclean
and recompilation?
Yes, tried that both. But I'll give it another try after checking
manually for any residues.
