[GRASS-dev] Compilation of most addons fails on build server
Most addons don't compile on the windows build server, all with a message such as:
"Makefile:7: /home/landa/src/grass74_release/dist.x86_64-pc-linux-gnu/include/Make/Script.make: No such file or directory
Makefile:8: /home/landa/src/grass74_release/dist.x86_64-pc-linux-gnu/include/Make/Python.make: No such file or directory
make: *** No rule to make target '/home/landa/src/grass74_release/dist.x86_64-pc-linux-gnu/include/Make/Python.make'. Stop."
or
"Makefile:5: /home/landa/src/grass74_release/dist.x86_64-pc-linux-gnu/include/Make/Script.make: No such file or directory
make: *** No rule to make target '/home/landa/src/grass74_release/dist.x86_64-pc-linux-gnu/include/Make/Script.make'. Stop."
That means the man pages are not accessible either (maybe we could have a system that if building fails, the man page from the last successfully compiled version is displayed ?).
Trying to see the build logs on Linux [1], I get an "Insecure connection" error:
"wingrass.fsv.cvut.cz uses an invalid security certificate. The certificate expired on 17/07/18 11:36. The current time is 20/07/18 11:31."
Moritz
[1] https://wingrass.fsv.cvut.cz/grass74/x86/addons/latest/logs/
On 20/07/18 11:34, Moritz Lennert wrote:
message such as:
"Makefile:7:
Makefile:8:
   Stop."
or
"Makefile:5:
   Stop."
connection" error:
Sorry, this should have been "build logs on Windows"
Moritz
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
