[GRASS-dev] Compilation options
Dear all,
Does someone of you know which modules benefit from --with-openmp and --with-opencl compilation options?
I found this explanation of compilation options: https://grass.osgeo.org/grass72/source/snapshot/REQUIREMENTS.html
But it does not cover OpenCL or OpenMP (as well as some few more other option).
If I wanted to find out myself, could I just search the code for modules that import the relevant headers of the respective libraries?
Or is that a bit more complex?
Another question is if it would be recommended to use the different options, as I understood e.g. using --with-pthread is not necessarily a good choice…
Thanks in advance.
Stefan
Hi again,
Seek and ye shall find…
So, there is:
https://grasswiki.osgeo.org/wiki/OpenMP#OpenMP_support_in_GRASS_7 and
https://grasswiki.osgeo.org/wiki/GPU
Which helped me a bit further.
However, my impression is that not all info there (esp. on OpenMP) is up to date (e.g. latest development like here: https://lists.osgeo.org/pipermail/grass-dev/2017-August/085711.html). Neither did it became very clear to me which modules already have robust and working support and which are just candidates or where initial implementations are available (sometimes outside the code base)…
Stefan
From: grass-dev [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Stefan Blumentrath
Sent: mandag 23. oktober 2017 09.24
To: GRASS developers list (grass-dev@lists.osgeo.org) grass-dev@lists.osgeo.org
Subject: [GRASS-dev] Compilation options
Dear all,
Thanks in advance.
Stefan
On Tue, Oct 24, 2017 at 10:27 AM, Stefan Blumentrath
<Stefan.Blumentrath@nina.no> wrote:
Hi again,
So, there is:
I updated it slightly to reflect the new modules, as always, more work
is needed on that page.
Anna
Stefan
Stefan Blumentrath
<grass-dev@lists.osgeo.org>
Dear all,
option).
Thanks in advance.
Stefan
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
Hei Anna,
Thanks for looking into this.
I did some tests with GRASS 7.2.1svn (r70188) and GRASS 7.3.svn (r70829) both compiled with --with-openmp
It seems that r.proj does not use multiple threads in GRASS 7.2 (not tested in 7.3. yet). v.surf.rst uses more cores in GRASS 7.2 with OpenMP but that does not bring down execution time at all. OpenMP seems to be disabled for v.surf.rst in GRASS 7.3. v.surf.bspline however, is significantly faster in GRASS 7.3 with OpenMP...
I will do some more, systematic tests and update the wiki entry as far as I can, if not someone with knowledge gets there first...
Stefan
P.S.: Some preliminary test results:
# OpenMP support test
$ OMP_NUM_THREADS=10
$ export OMP_NUM_THREADS
$ time v.surf.rst input=points elevation=test --o --qq
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
$ time v.surf.bspline elevrand column=value output=elev_full --o
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
-----Original Message-----
From: Anna Petrášová [mailto:kratochanna@gmail.com]
Sent: fredag 27. oktober 2017 17.00
To: Stefan Blumentrath <Stefan.Blumentrath@nina.no>
Cc: GRASS developers list (grass-dev@lists.osgeo.org) <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] Compilation options
On Tue, Oct 24, 2017 at 10:27 AM, Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
Hi again,
So, there is:
base)…
I updated it slightly to reflect the new modules, as always, more work is needed on that page.
Anna
Stefan
Dear all,
option).
a good choice…
Thanks in advance.
Stefan
v.surf.rst in trunk has nproc parameter, have you tried to use it?
Anna
On Oct 29, 2017 6:51 AM, “Stefan Blumentrath” <Stefan.Blumentrath@nina.no> wrote:
Hei Anna,
It seems that r.proj does not use multiple threads in GRASS 7.2 (not tested in 7.3. yet). v.surf.rst uses more cores in GRASS 7.2 with OpenMP but that does not bring down execution time at all. OpenMP seems to be disabled for v.surf.rst in GRASS 7.3. v.surf.bspline however, is significantly faster in GRASS 7.3 with OpenMP…
I will do some more, systematic tests and update the wiki entry as far as I can, if not someone with knowledge gets there first…
Stefan
OpenMP support test
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
Hi again,
So, there is:
base)…
Anna
Stefan
Dear all,
–with-opencl compilation options?
option).
a good choice…
Thanks in advance.
Stefan
Thanks for the hint.
I just tried:
time v.surf.rst elevrand zcol=value elevation=elev_full --o nprocs=10
Reading features from vector map …
Processing segments in parallel…
Starting parallel work
v.surf.rst complete.
real 0m33.814s
user 0m35.786s
sys 0m0.126s
Seems, that also with nprocs=10 and OMP_NUM_THREADS=10 v.surf.rst only uses one CPU in GRASS 7.3.svn (despite the message about parallel work)…
Stefan
Anna
Hei Anna,
Stefan
OpenMP support test
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
Hi again,
So, there is:
base)…
Anna
Stefan
Dear all,
option).
a good choice…
Thanks in advance.
Stefan
BTW: Would be nice to unify that in the long run, as a nprocs option would make parallelisation of a module also more evident and more convenient to control, compared to environment variables. Though it might be misleading if GRASS is not complied with OpenMP support (don`t know if that is the case in standard packages (OSGeo4W, UbuntuGIS…)).
There is no standard parser option for the number of parallel processes. Temporal modules use nprocs option as well, so maybe that can be considered a de facto standard (and possibly added to the parser?).
r.sun.mp calls it “threads” and other addons might again use yet other terms…
Just a thought, I can open a ticket if you think it is worth it…
Stefan
Anna
Hei Anna,
Stefan
OpenMP support test
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
Hi again,
So, there is:
base)…
Anna
Stefan
Dear all,
option).
a good choice…
Thanks in advance.
Stefan
On Sun, Oct 29, 2017 at 4:30 PM, Stefan Blumentrath
I just tried:
Reading features from vector map ...
Processing segments in parallel...
real 0m33.814s
user 0m35.786s
sys 0m0.126s
For me it works, try different dataset, you might see more difference
for larger datasets maybe:
GRASS 7.3.svn (nc_spm_08_coastal):~/dev/grass/trunk2 > time v.surf.rst
--overwrite input=elev_lidrural_mrpts@PERMANENT elevation=test
nprocs=4
WARNING: Some points outside of region (ignored)
WARNING: There are points outside specified 2D/3D region - 9663 points
         ignored
Ignoring 511 points (too dense)
WARNING: Overshoot - increase in tension suggested. Overshoot occurs at
         (662,749) cell. Z-value 98.513438, zmin 103.513005, zmax
         153.065828.
real 0m58.009s
user 3m41.476s
sys 0m0.304s
Stefan
Sent: søndag 29. oktober 2017 12.31
Cc: GRASS-dev <grass-dev@lists.osgeo.org>
Subject: RE: [GRASS-dev] Compilation options
Anna
On Oct 29, 2017 6:51 AM, "Stefan Blumentrath" <Stefan.Blumentrath@nina.no>
wrote:
Hei Anna,
Stefan
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
Hi again,
So, there is:
base)…
Anna
Stefan
Dear all,
option).
a good choice…
Thanks in advance.
Stefan
Thanks Anna,
Yes, now I can confirm that it works. The problem was that I did not adjust the region to where the points are which influenced computation so OpenMP did not kick-in.
So now:
g.region -p vector=elev_lidrural_mrpts res=1 -a
time v.surf.rst --overwrite input=elev_lidrural_mrpts@PERMANENT elevation=test nprocs=10
WARNING: Strip exists with insufficient data
Ignoring 701 points (too dense)
         (85,878) cell. Z-value 158.741920, zmin 102.227686, zmax
         153.065828.
100%
real 0m19.670s
user 2m19.833s
sys 0m0.446s
Compared to:
real 2m0.889s
user 2m0.332s
sys 0m0.251s
Cool!
Stefan
P.S.: using /usr/bin/time -v it seems that RAM usage increased by a factor of ~2.25 between 1 and 10 cores...
Sent: søndag 29. oktober 2017 23.00
On Sun, Oct 29, 2017 at 4:30 PM, Stefan Blumentrath <Stefan.Blumentrath@nina.no> wrote:
I just tried:
real 0m33.814s
user 0m35.786s
sys 0m0.126s
work)…
For me it works, try different dataset, you might see more difference for larger datasets maybe:
GRASS 7.3.svn (nc_spm_08_coastal):~/dev/grass/trunk2 > time v.surf.rst --overwrite input=elev_lidrural_mrpts@PERMANENT elevation=test
nprocs=4
         ignored
         153.065828.
real 0m58.009s
user 3m41.476s
sys 0m0.304s
Stefan
Anna
wrote:
Hei Anna,
Stefan
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
Hi again,
So, there is:
base)…
Anna
Stefan
Dear all,
other option).
a good choice…
Thanks in advance.
Stefan
I just ported r.sun.mp from addons to r.sun, so you are welcome to test that as well.
Anna
On Oct 30, 2017 5:28 AM, “Stefan Blumentrath” <Stefan.Blumentrath@nina.no> wrote:
Thanks Anna,
So now:
153.065828.
100%
real 0m19.670s
user 2m19.833s
sys 0m0.446s
Compared to:
real 2m0.889s
user 2m0.332s
sys 0m0.251s
Cool!
Stefan
P.S.: using /usr/bin/time -v it seems that RAM usage increased by a factor of ~2.25 between 1 and 10 cores…
I just tried:
real 0m33.814s
user 0m35.786s
sys 0m0.126s
work)…
nprocs=4
ignored
153.065828.
real 0m58.009s
user 3m41.476s
sys 0m0.304s
Stefan
Anna
wrote:
Hei Anna,
Stefan
OpenMP support test
real 51m42.224s
user 398m2.766s
sys 0m18.874s
$ OMP_NUM_THREADS=1
real 53m22.508s
user 53m10.607s
sys 0m4.793s
real 0m20.509s
user 3m11.412s
sys 0m1.963s
$ OMP_NUM_THREADS=1
real 1m15.434s
user 1m14.738s
sys 0m0.447s
Hi again,
So, there is:
base)…
Anna
Stefan
Dear all,
other option).
a good choice…
Thanks in advance.
Stefan
