I’m working to make a script for grass add_ons.
So, I’m trying to compile an individual module for understand how working.
I’ve seen the howto: http://grass.itc.it/grass63/source/INSTALL
I’ve tryed with a script of add_ons (r.in.onearth), I change the relative path
in the Makefile to absolute path. (MODULE_TOPDIR=/mydirectory
So it’s stopped, because it don’t such the file:
($MODULE_TOPDIR)/include/Make/Grass.make
($MODULE_TOPDIR)/include/Make/Platform.make
and “don’t have the rule to make target ($MODULE_TOPDIR)/include/Make/Grass.make”
so I’ve seen that the ($MODULE_TOPDIR)/include/Make/Grass.make don’t exist, but
exists a ($MODULE_TOPDIR)/include/Make/Grass.make.in file, but I’ve correctly installed
GRASS sorce code in my pc…
What’s the problem?
Thanks in advanced
R
COMPILING INDIVIDUAL MODULES - OWN MODULES
To compile (self-made) GRASS modules or to compile modified modules
at least the GRASS libraries have to be compiled locally. This is
done by launching:
make libs
Then change into the module's directory and launch the "make"
command. The installation can be either done with "make install" from
the main source code directory or locally with
"INST_NOW=y make"
You may want to define an alias for this:
alias gmake6='INST_NOW=y make'
Then simply compile/install the current module with
gmake6
Note: If you keep your module source code outside the standard GRASS
source code directory structure, you will have to change the relative
path(s) in the Makefile to absolute path(s).
2008/3/12, roberto marzocchi <roberto.marzocchi@gmail.com>:
I've seen the howto:
I've tryed with a script of add_ons (r.in.onearth), I change the relative
path
So it's stopped, because it don't such the file:
and "don't have the rule to make target
($MODULE_TOPDIR)/include/Make/Grass.make"
so I've seen that the
($MODULE_TOPDIR)/include/Make/Grass.make don't exist, but
but I've correctly installed
you need to run configure with proper switches to generate Grass.make
and others.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
I've to run configure under GRASS directory?
yes, in the root GRASS source code directory.
Martin
It's correct? Just for a module?
thank you very much
R
2008/3/12, Martin Landa <landa.martin@gmail.com>:
> Hi,
relative
> > path
but
file,
> and others.
> Martin
