[GRASS-dev] Compile error on Kubuntu 7.04
Hi Listers,
I am trying to compile GRASS-6.3.cvs on my recently installed Kubuntu (7.04, Fiesty Fawn) system. I’ve successfully compiled before on the same laptop (a toshiba r 10) under MEPIS 6 (also ubuntu based) and MEPIS 3.4.2 (debian based). However this time I get the following error that I don’t really understand:
make[1]: Entering directory /home/isaac/Desktop/grass63-cvs-source/locale' Creating translations (= 'make mo') make[2]: Entering directory /home/isaac/Desktop/grass63-cvs-source/locale’
grasslibs_ar.po: /bin/sh: msgfmt: not found
grasslibs_cs.po: /bin/sh: msgfmt: not found
grasslibs_de.po: /bin/sh: msgfmt: not found
grasslibs_el.po: /bin/sh: msgfmt: not found
grasslibs_es.po: /bin/sh: msgfmt: not found
grasslibs_fr.po: /bin/sh: msgfmt: not found
grasslibs_hi.po: /bin/sh: msgfmt: not found
grasslibs_it.po: /bin/sh: msgfmt: not found
grasslibs_ja.po: /bin/sh: msgfmt: not found
grasslibs_ko.po: /bin/sh: msgfmt: not found
grasslibs_lv.po: /bin/sh: msgfmt: not found
grasslibs_mr.po: /bin/sh: msgfmt: not found
grasslibs_pl.po: /bin/sh: msgfmt: not found
grasslibs_pt_br.po: /bin/sh: msgfmt: not found
grasslibs_ru.po: /bin/sh: msgfmt: not found
grasslibs_sl.po: /bin/sh: msgfmt: not found
grasslibs_tr.po: /bin/sh: msgfmt: not found
grasslibs_vi.po: /bin/sh: msgfmt: not found
grasslibs_zh.po: /bin/sh: msgfmt: not found
grassmods_ar.po: /bin/sh: msgfmt: not found
grassmods_cs.po: /bin/sh: msgfmt: not found
grassmods_de.po: /bin/sh: msgfmt: not found
grassmods_el.po: /bin/sh: msgfmt: not found
grassmods_es.po: /bin/sh: msgfmt: not found
grassmods_fr.po: /bin/sh: msgfmt: not found
grassmods_hi.po: /bin/sh: msgfmt: not found
grassmods_it.po: /bin/sh: msgfmt: not found
grassmods_ja.po: /bin/sh: msgfmt: not found
grassmods_ko.po: /bin/sh: msgfmt: not found
grassmods_lv.po: /bin/sh: msgfmt: not found
grassmods_mr.po: /bin/sh: msgfmt: not found
grassmods_pl.po: /bin/sh: msgfmt: not found
grassmods_pt_br.po: /bin/sh: msgfmt: not found
grassmods_ru.po: /bin/sh: msgfmt: not found
grassmods_sl.po: /bin/sh: msgfmt: not found
grassmods_tr.po: /bin/sh: msgfmt: not found
grassmods_vi.po: /bin/sh: msgfmt: not found
grassmods_zh.po: /bin/sh: msgfmt: not found
grasstcl_ar.po: /bin/sh: msgfmt: not found
grasstcl_cs.po: /bin/sh: msgfmt: not found
grasstcl_de.po: /bin/sh: msgfmt: not found
grasstcl_el.po: /bin/sh: msgfmt: not found
grasstcl_es.po: /bin/sh: msgfmt: not found
grasstcl_fr.po: /bin/sh: msgfmt: not found
grasstcl_hi.po: /bin/sh: msgfmt: not found
grasstcl_it.po: /bin/sh: msgfmt: not found
grasstcl_ja.po: /bin/sh: msgfmt: not found
grasstcl_ko.po: /bin/sh: msgfmt: not found
grasstcl_lv.po: /bin/sh: msgfmt: not found
grasstcl_mr.po: /bin/sh: msgfmt: not found
grasstcl_pl.po: /bin/sh: msgfmt: not found
grasstcl_pt_br.po: /bin/sh: msgfmt: not found
grasstcl_ru.po: /bin/sh: msgfmt: not found
grasstcl_sl.po: /bin/sh: msgfmt: not found
grasstcl_tr.po: /bin/sh: msgfmt: not found
grasstcl_vi.po: /bin/sh: msgfmt: not found
grasstcl_zh.po: /bin/sh: msgfmt: not found
make[2]: *** [mo] Error 127
make[2]: Leaving directory /home/isaac/Desktop/grass63-cvs-source/locale' make[1]: *** [default] Error 2 make[1]: Leaving directory /home/isaac/Desktop/grass63-cvs-source/locale’
make: *** [default] Error 2
Does anyone know what the problem is here? I’ve never seen this error during any of the other times I’ve compiled GRASS… Any help would be greatly appreciated!
Isaac
Isaac I Ullah, M.A.
Archaeology PhD Student,
ASU School of Evolution and Social Change
Research Assistant,
Mediterranean Landscape Dynamics Project
isaac.ullah@asu.edu
ullah@archaeologist.com
http://www.public.asu.edu/~iullah
Hi Isaac. You don't seem to have gettext installed. Try to apt-get
install gettext.
Daniel.
On 6/8/07, Isaac Ullah <isaac.ullah@asu.edu> wrote:
Hi Listers,
(7.04, Fiesty Fawn) system. I've successfully compiled before on the same
(debian based). However this time I get the following error that I don't
really understand:
`/home/isaac/Desktop/grass63-cvs-source/locale'
Does anyone know what the problem is here? I've never seen this error during
any of the other times I've compiled GRASS... Any help would be greatly
appreciated!
Isaac
Isaac I Ullah, M.A.
Research Assistant,
isaac.ullah@asu.edu
grass-dev mailing list
grass-dev@grass.itc.it
-- Daniel Calvelo Aros
Shouldn't missing gettext (msgfmt) executable been catched by
"./configure --with-nls" as error? IMHO this should be reported as
bug.
Maris.
2007/6/9, Daniel Calvelo <dca.gis@gmail.com>:
install gettext.
Daniel.
> Hi Listers,
> really understand:
during
> appreciated!
> Cheers,
> Isaac
> Isaac I Ullah, M.A.
> Research Assistant,
> isaac.ullah@asu.edu
