[GRASS-dev] compile error?
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
I'm getting an error during compilation (yet, I tried running make
distclean, but it doesn't help).
Any explanation?
Thanks.
pc
Installing with make install...
======================= Installation results =======================
echo /home/paolo/Desktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63
/bin/sh: line 5: [: =: unary operator expected
make[1]: Entering directory `/home/paolo/Desktop/buildpackage/grass6'
test -d /usr/local/grass-6.3.cvs || mkdir -p -m 755 /usr/local/grass-6.3.cvs
test -d /usr/local/bin || mkdir -p -m 755 /usr/local/bin
sed -e "s#^GISBASE.*#GISBASE=/usr/local/grass-6.3.cvs#" /home/paolo/Desktop/
buildpackage/grass6/bin.i686-pc-linux-gnu/grass63 > /usr/local/bin/grass63
chmod a+x /usr/local/bin/grass63
sed -e "s#^WINGISBASE.*#WINGISBASE=/usr/local/grass-6.3.cvs#" /home/paolo/De
sktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63.bat > /usr/local/bin
/grass63.bat
chmod a+x /usr/local/bin/grass63.bat
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf
- - bin | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
make[1]: [real-install] Error 2 (ignored)
- - bwidget | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
- - docs | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
- - driver | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
- - etc | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
- - fonts | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - man | (cd /usr/local/grass-6.3.cvs ; tar
xBf - ) 2>/dev/null
cBf - scripts | (cd /usr/local/grass-6.3.cvs ;
if [ 1 -eq 1 ] ; then cd
    c-linux-gnu ; tar cBf - locale | (cd /usr/local/grass-6.3.cvs ; tar
xBf - ) 2>/dev/null ; fi
make[1]: *** [real-install] Error 2
make[1]: Leaving directory `/home/paolo/Desktop/buildpackage/grass6'
make: *** [install] Error 2
**** Installation failed. Aborting package creation.
Paolo Cavallini
http://www.faunalia.it/pc
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGENNg/NedwLUzIr4RAm/yAJ0TmttS7r9BglwnLioSGnE3zezj+ACgtgrO
T6ssS+kYLARdG/Xiwqnk0+o=
=gAU6
-----END PGP SIGNATURE-----
Hash: SHA1
Hi all.
Any explanation?
Thanks.
pc
Fixed in CVS. MACOSX_APP must be quoted in the Makefile.
Sorry about that.
Would this also affect when it's used in ifeq() ? ie:
ifeq ($(MACOSX_APP),1)
Hash: SHA1
Hi all.
Any explanation?
Thanks.
pc
grass-dev mailing list
grass-dev@grass.itc.it
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
Hash: SHA1
Thanks. However, it still fails:
========================= Installation results ======================
/home/paolo/Desktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63 >
/home/paolo/Desktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63.bat
cBf - bin | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - bwidget | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - docs | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - driver | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - etc | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - fonts | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - man | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cBf - scripts | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
- - locale | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null ; fi
Hash: SHA1
Hi all.
Any explanation?
Thanks.
pc
Paolo Cavallini
iD8DBQFGESBg/NedwLUzIr4RApg9AJ9fiv/VjmbUEvze9El5gCzHCRvvwQCfdeas
A9ulRamKHmjhCybQAvaF5lk=
=007o
No, that's okay.
It's only in (some) shell commands where it needs to be quoted.
sed -e "s#^WINGISBASE.*#WINGISBASE=/usr/local/grass-6.3.cvs#" /home/paolo/Desktop/buildpackage/grass6/bin.i686-pc-linux-gnu/grass63.bat > /usr/local/bin/grass63.bat
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - bin | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - bwidget | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - docs | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - driver | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - etc | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - fonts | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - man | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - scripts | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null
if [ 1 -eq 1 ] ; then cd /home/paolo/Desktop/buildpackage/grass6/dist.i686-pc-linux-gnu ; tar cBf - - locale | (cd /usr/local/grass-6.3.cvs ; tar xBf - ) 2>/dev/null ; fi
Can you try running the failing commands manually without the
"2>/dev/null", e.g.
Hash: SHA1
Hi Glynn.
Thanks for help. I removed the old directory (/usr/local/grass-6.3.cvs),
and make install went smoothly.
All the best.
pc
"2>/dev/null", e.g.
Paolo Cavallini
iD8DBQFGEfIg/NedwLUzIr4RAqEZAJwPJfqkul9sJj4Gk3Cshqjh2UKXiACePRwz
pc3jKz8wOckp5NThCOn/c7E=
=kOr3
