Lots of compile errors on make on my vista machine (using mingw/msys
not osgeo4w). This is the first one, from lib/datetime:
gcc -shared -o /usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.6.4.0svn.dll
-L/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib
-Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/usr/local/lib
-L/usr/local/pgsql/lib OBJ.i686-pc-mingw32/between.o
OBJ.i686-pc-mingw32/copy.o OBJ.i686-pc-mingw32/same.o
OBJ.i686-pc-mingw32/diff.o OBJ.i686-pc-mingw32/error.o
OBJ.i686-pc-mingw32/format.o OBJ.i686-pc-mingw32/incr1.o
OBJ.i686-pc-mingw32/incr2.o OBJ.i686-pc-mingw32/incr3.o
OBJ.i686-pc-mingw32/local.o OBJ.i686-pc-mingw32/misc.o
OBJ.i686-pc-mingw32/change.o OBJ.i686-pc-mingw32/scan.o
OBJ.i686-pc-mingw32/sign.o OBJ.i686-pc-mingw32/type.o
OBJ.i686-pc-mingw32/tz1.o OBJ.i686-pc-mingw32/tz2.o
OBJ.i686-pc-mingw32/values.o
../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o && \
(cd /usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib;
ln -f -s libgrass_datetime.6.4.0svn.dll
/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.dll)
gcc.exe: ../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o: No such file or directory
make: *** [/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/lib/libgrass_datetime.6.4.0svn.dll]
Error 1
and from lib/gis:
make: *** No rule to make target
`../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o', needed by `default'.
Stop.
The errors seem to be related to the dllmain and fmode problems from
ticket #469 <http://trac.osgeo.org/grass/ticket/469>, but they seem to
affect only the versions post-fix. While releasebranch_6_4 and
develbranch_6 have make errors, releasebranch_6_3 doesn't have these
errors.
-Colin
Error 1
and from lib/gis:
Stop.
errors.
It appears that someone committed only half of the fix with r35770.
[Probably because a complete fix doesn't exist; the change implies
that dllmain.c would be part of lib/gis, but lib/datetime is built
first.]
The easiest solution is likely to be to simply revert the change with:
svn merge -c -35770 .
Unless someone can come up with a real fix, I'll revert r35770 in SVN.
On Tue, Mar 3, 2009 at 3:58 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
Error 1
and from lib/gis:
Stop.
errors.
The fixes were
- 6.4.svn (r35767, r35769)
- 6.4.0svn (r35768, r35770)
first.]
What is exactly missing?
To my knowledge, it compiles on MingW for the OSGeo4W compiler as well
as Linux and MacOSX.
svn merge \-c \-35770 \.
Wait a moment... (also note that r35768 + r35770 are belonging together).
Suggestion:
In include/Make/Shlib.make, change the
ifdef MINGW
test to something which excludes $(DATETIME_LIBNAME)?
Then it's applied only when not building libgrass_datetime.
Marksu
>> Error 1
>> and from lib/gis:
>> Stop.
>> errors.
The fixes were
> first.]
dllmain.c.
But hang on: DLLMAIN_OBJ doesn't appear to be defined anywhere in
develbranch_6.
Never mind. Someone who actually has the relevant versions checked out
will need to look into this. I think I'm just going to stick to 7.x
from now on.
On Wed, Mar 4, 2009 at 3:25 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
>> Error 1
>> and from lib/gis:
>> Stop.
>> errors.
The fixes were
> first.]
dllmain.c.
develbranch_6.
I seem to have a different version:
[neteler@localhost grass64]$ grep DLLMAIN_OBJ include/Make/* lib/gis/Makefile
include/Make/Shlib.make: DLLMAIN_OBJ =
$(MODULE_TOPDIR)/lib/gis/$(OBJDIR)/dllmain.o
include/Make/Shlib.make: $(SHLIB_LD) -o $@ $(LDFLAGS) $^
$(EXTRA_LIBS) $(DLLMAIN_OBJ) && \
lib/gis/Makefile:default: $(DLLMAIN_OBJ) lib $(FMODE_OBJ) $(DATAFILES)
$(COLORFILES) $(ETC)/colors.desc $(ETC)/element_list
Also 6.4.0svn:
[neteler@localhost grass64_release]$ grep DLLMAIN_OBJ include/Make/*
lib/gis/Makefile
Can anyone else confirm?
from now on.
>> The fixes were
>> > first.]
> dllmain.c.
> develbranch_6.
Er, right; my Shlib.make was modified to remove the DLLMAIN_OBJ stuff
(probably to get it to compile).
On Wed, Mar 4, 2009 at 12:07 PM, Glynn Clements
>> The fixes were
>> > first.]
> dllmain.c.
> develbranch_6.
On which platform did it fail?
>> >> The fixes were
>> >> > first.]
>> > dllmain.c.
>> > develbranch_6.
Actually, that's probably not it. But for whatever reason, I have a
modified version without the changes.
It will fail on MinGW, as the changes add dllmain.o to the link
command but don't provide any way for that file to be created.
On Wed, Mar 4, 2009 at 5:47 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
>> >> The fixes were
>> >> > first.]
>> > dllmain.c.
>> > develbranch_6.
Here is what's in SVN:
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/include/Make/Shlib.make
http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/lib/gis/Makefile
Ha!
No trace of dllmain.c in
I'm confused. Perhaps our radio-bridge based internet connection in the
office failed silently. Submitted (again) in r36196 for devel_branch6.
In 6.4.0svn it was already present.
Please give the compilation another try.
Colin, too...
The entire change is yet missing in grass 7 as I don't know
how to modify the Makefiles appropriately. The patches of
the trac ticket won't work.
Still not working, sorry. I'm still a bit new at this so I'll give you
my steps to make sure I didn't miss anything
1) svn up
2) make clean
3) config.status --recheck
4) make
Result:
$ make > /dev/null
make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_datetime.6.5.svn.dll]
Error 1
make[3]: *** No rule to make target
Stop.
make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_gmath.6.5.svn.dll]
Error 1
make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_linkm.6.5.svn.dll]
Error 1
make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_driver.6.5.svn.dll]
Error 1
make[3]: *** [/usr/local/src/grass6_devel/dist.i686-pc-mingw32/lib/libgrass_pngdriver.6.5.svn.dll]
Error 1
There were many more errors in lib, db, display, vector, raster, etc.
I'll keep being the mingw/msys test bed if you propose other possible
solutions.
-Colin
>> >> The fixes were
>> >> > first.]
>> > dllmain.c.
>> > develbranch_6.
Ha!
Colin, too...
Devs,
Colin tried attached patch and with that DATETIME builds
but then the problem continues for the other libraries.
I am no good at reading Makefiles, help needed.
On Thu, Mar 5, 2009 at 5:24 PM, Colin Nielsen <colin.nielsen@gmail.com> wrote:
1) svn up
2) make clean
4) make
Result:
$ make > /dev/null
Error 1
Stop.
Error 1
Error 1
Error 1
Error 1
solutions.
-Colin
>> >> The fixes were
>> >> > first.]
>> > dllmain.c.
>> > develbranch_6.
Ha!
Colin, too...
(attachments)
mingw.diff (588 Bytes)
1) svn up
2) make clean
4) make
Result:
$ make > /dev/null
Error 1
AFAICT, this is because the rule in lib/gis/Makefile uses a path based
upon MODULE_TOPDIR, but the compilation rules require a path relative
to the current directory. The first attached patch should fix this part.
The second patch should fix the issue with lib/datetime being built
before lib/gis. If it doesn't, just try running "make" a second time
without an intervening "make clean".
Stop.
Error 1
Error 1
Error 1
Error 1
solutions.
(attachments)
dllmain.patch (700 Bytes)
dllmain2.patch (496 Bytes)
1) I reverted markus's patch and the jef_mingw patch as well.
2) make distclean
3) ./configure etc etc etc
4) make
5) as Glynn suggested, make again
Seems to still be a lot of errors, so far the jef_mingw patch worked
the best, it fixed dllmain but not fmode.
-Colin
1) svn up
2) make clean
4) make
Result:
$ make > /dev/null
directory
make[3]: ***
Error 1
Stop.
directory
make[3]: ***
Error 1
directory
make[3]: ***
Error 1
directory
make[3]: ***
Error 1
directory
make[3]: ***
Error 1
directory
solutions.
(attachments)
make2.log (74.7 KB)
On Fri, Mar 6, 2009 at 11:52 AM, Glynn Clements
Error 1
I have merged that into a revised patch in
http://trac.osgeo.org/grass/ticket/519
Colin, could you please try that?
Further doubts in the ticket.
I applied the patches and recompiled. Still lots of errors I'm afraid.
I've attached the make errors.
The first major error is with lib/gis
-Colin
Error 1
(attachments)
make.log (107 KB)
2) make distclean
4) make
fmode.c seems to have disappeared at some point.
Eventually, I managed to get it to compile with the attached patch.
(attachments)
dllmain.patch (1.66 KB)
On Sun, Mar 8, 2009 at 9:07 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
2) make distclean
4) make
(mysterious, in 6.4.0svn it was present).
submitted to both 6.4.0svn and 6.5.svn.
if you have time: does 6.5.svn compile now?
I am happy to report that 6.5.svn compiles now, straight off of the
svn. (As usual with mingw, only the lidar modules fail.)
Congratulations. However, I think something is missing from 6.4.0svn
because there is still an fmode error in lib/gis. Or maybe you just
haven't backported the fixes yet.
$ make
gcc -I/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/include
-I/usr/local/include -g -O2 -I/usr/local/include
-DPACKAGE=\""grasslibs"\" -D_FILE_OFFSET_BITS=64 -DGDAL_LINK=1
-DGDAL_DYNAMIC=1 -DPACKAGE=\""grasslibs"\" -I/usr/local/include
-I/usr/local/src/grass-6.4_release/dist.i686-pc-mingw32/include -o
OBJ.i686-pc-mingw32/fmode.o -c fmode.c
fmode.c:8: error: redefinition of '_fmode'
fmode.c:4: error: previous definition of '_fmode' was here
make: *** [OBJ.i686-pc-mingw32/fmode.o] Error 1
thanks for not giving up,
No problem.
-Colin
On Sun, Mar 8, 2009 at 11:27 PM, Colin Nielsen <colin.nielsen@gmail.com> wrote:
svn.
finally! great.
please send the error(s).
$ make
Fixed in 6.4.0svn: I have made a full diff of include/ and lib/gis/ and
found a difference in fmode.c. now they are back in sync.
The entire stuff needs to be merged in GRASS 7 later (since the Makefile
system is different, I leave that to someone else).
Please check if the remaining 4-5 patches in
are necessary.
The lidar module problems have been around for a while now
(http://grass.osgeo.org/wiki/WinGRASS_Current_Status).
I've attached the errors for the r.li dir.
are necessary.
I could be wrong, but it looks like the lidar part of the patch has
caused two attempts to make r.li. Each module in r.li.* has two
entries in error.log.
I'm not sure what the gdal patch does, but I did have some problems
getting gdal working in the past (I can't remember exactly what the
problem was), so perhaps this has fixed that. And likewise, xdr has
apparently been a problem under mingw as well
(http://lists.osgeo.org/pipermail/grass-windows/2008-December/001611.html).
spawn and g3d I have no idea, but from my make.log
C:/MinGW/msys/local/src/grass-6.4_release/dist.i686-pc-mingw32/include/grass/gis.h:48:1:
warning: this is the location of the previous definition
spawn.c: In function `G_spawn':
spawn.c:84: warning: passing arg 3 of `_spawnv' from incompatible pointer type
spawn.c: In function `do_spawn':
spawn.c:234: warning: passing arg 3 of `spawnvpe' from incompatible pointer type
spawn.c:234: warning: passing arg 4 of `spawnvpe' from incompatible pointer type
I think that's all I can offer at this point. I'm sure jef can clear
up the last details.
-Colin
(attachments)
lidar.log (4 KB)
