[GRASS-dev] CompileOnWindows finished
hi Colin,
it's a good work! Compiling on Win Vista Business is working.
Some ideas:
- Is this procedere also working for GRASS7? if yes, could a hint be added to the wiki?
- Would it be possible to add GRASS-cairo-functionality for WinGRASS?
Maybe under http://www.jkrieger.de/programming/cpp/gnulibs.html or http://inkscape.modevia.com/win32libs/ some mingw-
packages of cairo?
- Would it be possible to add some hints in the wiki about what to do if compiling a new version of the source-code?
best regards
Helmut
I just wanted to announce that the CompileOnWindows wiki entry
<http://trac.osgeo.org/grass/wiki/CompileOnWindows&gt; is finished and
now allows anyone to develop grass on windows (vista or xp) through
the mingw/msys system with no dependency compiling and relatively
little extra work (thanks to jef for solving all remaining issues by
adding the mingw-libs package to the wiki).
-Colin
____________________________________________________________________
Psssst! Schon vom neuen WEB.DE MultiMessenger gehört?
Der kann`s mit allen: http://www.produkte.web.de/messenger/?did=3123
packages of cairo?
I've added a couple of packages to the TODO section of the wiki page,
that may work. I haven't tried them personally, so report back if you
find success. I've also opened an enhancement ticket on osgeo4w's
tracker to request cairo and cairo-dev be added to their tree.
Done and done :slight_smile:
-Colin
On Sun, Mar 29, 2009 at 5:46 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
hi Colin,
Some ideas:
packages of cairo?
best regards
Helmut
-Colin
grass-dev mailing list
grass-dev@lists.osgeo.org
