[GRASS-dev] Compiler error in /lib/calc
[Response to Re: [GRASS-dev] grass-dev Digest, Vol 149, Issue 11]
Hi Michael,
I’m not able to reproduce this issue on Linux with clang (which is used on Mac) even with more strict compiler settings:
clang -O2 -fno-common -Wall -pedantic -Wextra …
Since both “installation/dist” and source paths appear in the command line, even the error message says the function is there (actually, already in the installed/dist path), the includes were not changed (in r72940), and the errors are only related to the newly added functions (f_ceil, f_floor), I suggest just updating and recompiling again and making sure that two source codes or installations are not tangled together.
For the record, this is not related to m.nviz.image changes. It might be related to r72940 r.mapcalc: +ceil, +floor (fixes #769).
Best,
Vaclav
On Thu, Jul 5, 2018 at 5:14 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
To try and test the fix to m.nviz.image, I just now did for trunk:
Make distclean
Svn update
Configure (no problem)
Compile
I got a compiler error in /lib/calc (error below)
Is this due to the recent fix?
I also tried it with a completely new version of trunk downloaded and got the same errors.
Michael
========== error ==========
Errors in:
/Users/cmbarton/grass_source/trunk/lib/calc
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Thu Jul 5 13:47:36 MST 2018
make: *** [default] Error 1
cmb-imaccsdc:trunk cmbarton$ cd /Users/cmbarton/grass_source/trunk/lib/calc
cmb-imaccsdc:calc cmbarton$ make
/Applications/GRASS-7.5.app/Contents/Resources/bin/clang -I/Applications/GRASS-7.5.app/Contents/Resources/include -g -O2 -fno-common -I/Applications/GRASS-7.5.app/Contents/Resources/include -I/Users/cmbarton/grass_source/trunk/dist.x86_64-apple-darwin17.6.0/include -I/Users/cmbarton/grass_source/trunk/dist.x86_64-apple-darwin17.6.0/include -DPACKAGE="“grasslibs”" -I/Users/cmbarton/grass_source/trunk/dist.x86_64-apple-darwin17.6.0/include -I/Users/cmbarton/grass_source/trunk/dist.x86_64-apple-darwin17.6.0/include -DRELDIR="lib/calc" -o OBJ.x86_64-apple-darwin17.6.0/function.o -c function.c
function.c:14:22: error: use of undeclared identifier ‘f_ceil’
{“ceil”, c_unop, f_ceil},
function.c:15:23: error: use of undeclared identifier ‘f_floor’; did you mean ‘f_float’?
{“floor”, c_unop, f_floor},
f_float
/Applications/GRASS-7.5.app/Contents/Resources/include/grass/defs/calc.h:63:15: note: ‘f_float’ declared here
extern func_t f_float;
2 errors generated.
make: *** [OBJ.x86_64-apple-darwin17.6.0/function.o] Error 1
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On 7/5/18, 12:00 PM, “grass-dev on behalf of grass-dev-request@lists.osgeo.org” <grass-dev-bounces@lists.osgeo.org on behalf of grass-dev-request@lists.osgeo.org> wrote:
Date: Thu, 05 Jul 2018 03:23:44 -0000
To: undisclosed-recipients: ;
Cc: grass-dev@lists.osgeo.org
Subject: Re: [GRASS-dev] [GRASS GIS] #2998: m.nviz.image fails with X
Error BadValue integer parameter out of range for operation
Message-ID: <060.01ef0c91d1c90d09d0aa6600166f8b24@osgeo.org>
Content-Type: text/plain; charset=“utf-8”
#2998: m.nviz.image fails with X Error BadValue integer parameter out of range for
operation
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.4
Component: LibOpenGL | Version: svn-trunk
Resolution: fixed | Keywords: m.nviz.image, NVIZ, 3D, GLX,
| X_GLXCreateContext, g.gui.animation
CPU: x86-64 | Platform: Linux
Comment (by hcho):
Oh! I’m on Linux (Slackware 14.2). Is there a way to reproduce your issue?
Any sample data set and command line? Maybe, it was related to my mistake
in write_img.c, which is just fixed in r72951?
Ticket URL: <https://urldefense.proofpoint.com/v2/url?u=https-3A__trac.osgeo.org_grass_ticket_2998-23comment-3A19&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=dAPexcceMdlawW6E7rSolX7s8mY6Jql0drLwOwoKKfc&s=5uNzqfWlMr40jdzC0Ny-QDAl8hVGhUxCxrhXgMOr2gQ&e=>
GRASS GIS <https://urldefense.proofpoint.com/v2/url?u=https-3A__grass.osgeo.org&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=lk-7X7CEOMDN8GaGVhiDsuO6gEp1wbG6nfT1XEEEtR0&m=dAPexcceMdlawW6E7rSolX7s8mY6Jql0drLwOwoKKfc&s=RZLKiXtG8s2xqATPclFfuTwSQ6hpancGROIW78AqtI4&e=>
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
