[GRASS-dev] compiling 7.0 on MacOS 10.9
Has anyone compiled GRASS 7.0 on MacOS Mavricks? Any tips?
Micha Silver
GIS Consulting
052-3665918
[http://www.surfaces.co.il](http://www.surfaces.co.il)
Micha,
i use homebrew to satisfy the dependencies for grass7
./configure
–with-opengl-includes=/opt/X11/include/
–with-opengl-libs=/opt/X11/lib/
–with-cairo-includes=/usr/local/Cellar/cairo/1.12.16/include/cairo/
–with-cairo-libs=/usr/local/Cellar/cairo/1.12.16/lib/
–with-freetype-includes=/usr/local/include/freetype2
–with-blas
–with-geos
–with-lapack
–with-netcdf
–with-odbc
–with-pthread
–with-postgres
–with-sqlite
–with-wxwidgets=/usr/local/Cellar/wxmac/3.0.0.0/bin/wx-config
the build ends with Errors in:
/Users/epi/dev/grass7_trunk/lib/nviz
/Users/epi/dev/grass7_trunk/misc/m.nviz.image
/Users/epi/dev/grass7_trunk/visualization/wximgview
The modules are all fully functionals but because i use python from home-brew as well (not the system one)
it is 64 bit and is not compatible with wx-2.8 … i have wx3.0 installed (that’s 64bit) but the main gui doesn’t start.
This the log from :
g.gui gui=wxpython
Launching GUI in the background, please wait…
GRASS 7.0.svn (nc_spm_08_grass7):~ > Traceback (most recent call last):
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/wxgui.py”, line 143, in
sys.exit(main())
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/wxgui.py”, line 136, in main
app = GMApp(workspaceFile)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/wxgui.py”, line 50, in init
wx.App.init(self, False)
File “/usr/local/Cellar/python/2.7.6/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/wx-3.0-osx_cocoa/wx/_core.py”, line 8631, in init
self._BootstrapApp()
File “/usr/local/Cellar/python/2.7.6/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/wx-3.0-osx_cocoa/wx/_core.py”, line 8196, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/wxgui.py”, line 84, in OnInit
workspace = self.workspaceFile)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/lmgr/frame.py”, line 109, in init
self._menuTreeBuilder = LayerManagerMenuData()
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/lmgr/menudata.py”, line 40, in init
MenuTreeModelBuilder.init(self, filename, expandAddons=expandAddons)
File “/usr/local/grass-7.0.svn/etc/gui/wxpython/core/menutree.py”, line 69, in init
xmlTree = etree.parse(filename)
File “/usr/local/Cellar/python/2.7.6/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 1182, in parse
tree.parse(source, parser)
File “/usr/local/Cellar/python/2.7.6/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 657, in parse
self._root = parser.close()
File “/usr/local/Cellar/python/2.7.6/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 1654, in close
self._raiseerror(v)
File “/usr/local/Cellar/python/2.7.6/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py”, line 1506, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
the wx dialog for (most but not all **) the grass modules, works fine.
** command like g.region, r.mask and others do not lunch a gui dialog when type their name in the grass shell.
Massimo.
Micha Silver
GIS Consulting
052-3665918
[http://www.surfaces.co.il](http://www.surfaces.co.il/)
grass-dev@lists.osgeo.org
Thanks.
We would be satisfied to get it working without the gui for now. But even that threw many more errors when compiling.
We had to have a huge configure line, pointing many --with-xxx-includes= and --with-xxx-libs= to the /usr/local/Cellar directory. Otherwise it did not find them.
On 02/04/2014 11:37, epi wrote:
Micha,
./configure
–with-blas
–with-geos
–with-lapack
–with-netcdf
–with-odbc
–with-pthread
–with-postgres
–with-sqlite
This the log from :
g.gui gui=wxpython
sys.exit(main())
self._raiseerror(v)
raise err
Massimo.
_______________________________________________ grass-dev mailing list
This mail was received via Mail-SeCure System.
Micha Silver
GIS Consulting
052-3665918
Micha Silver
GIS Consulting
052-3665918
This looks like a problem to link OpenGL.
This looks like a problem to link wxWidgets (the C++ library, not the
Python binding wxPython).
This the log from :
g.gui gui=wxpython
Launching <wxpython> GUI in the background, please wait...
  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/wxgui.py", line 143, in
<module>
  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/lmgr/menudata.py", line
40, in __init__
    MenuTreeModelBuilder.__init__(self, filename,
  File "/usr/local/grass-7.0.svn/etc/gui/wxpython/core/menutree.py", line
69, in __init__
  File
"/usr/local/Cellar/python/2.7.6/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
    raise err
This is probably caused by the fact that compilation for gui/wxpython/xml
failed. I secretly hoped that this will be improved by r59485, are you
using that version? The workaround used before was delete
dist.../etc/gui/wxpython/xml and then run compilation of gui/wxpython
inside GRASS session.
https://trac.osgeo.org/grass/changeset/59485 (modify Rules.make to fix
build_modules_xml.py on Windows (TODO: replace this workaround))
http://lists.osgeo.org/pipermail/grass-dev/2014-March/067876.html (get
interface description for python modules on Windows)
This is actually standard behavior. Probably not documented well. This is
how g.region parameters are handled. Use `g.region --ui`.
Massimo.
Micha Silver
GIS Consulting
052-3665918http://www.surfaces.co.il
That’s correct, for some reason seems that it doesn’t detect the right architecture :
MacBook-Pro-di-Massimo-2:nviz epi$ make
cc -dynamiclib -compatibility_version 7.1 -current_version 7.1 -install_name /usr/local/grass-7.1.svn/lib/libgrass_nviz.7.1.svn.dylib -o /Users/epi/dev/grass7_trunk/dist.x86_64-apple-darwin13.1.0/lib/libgrass_nviz.7.1.svn.dylib -L/Users/epi/dev/grass7_trunk/dist.x86_64-apple-darwin13.1.0/lib -L/Users/epi/dev/grass7_trunk/dist.x86_64-apple-darwin13.1.0/lib -L/usr/local/opt/tcl-tk/lib -arch x86_64 OBJ.x86_64-apple-darwin13.1.0/change_view.o OBJ.x86_64-apple-darwin13.1.0/cplanes_obj.o OBJ.x86_64-apple-darwin13.1.0/draw.o OBJ.x86_64-apple-darwin13.1.0/exag.o OBJ.x86_64-apple-darwin13.1.0/lights.o OBJ.x86_64-apple-darwin13.1.0/map_obj.o OBJ.x86_64-apple-darwin13.1.0/nviz.o OBJ.x86_64-apple-darwin13.1.0/position.o OBJ.x86_64-apple-darwin13.1.0/render.o -lgrass_ogsf.7.1.svn -lgrass_gis.7.1.svn -L/opt/X11/lib/ -lGL
Undefined symbols for architecture x86_64:
“_XCloseDisplay”, referenced from:
_Nviz_destroy_render_window in render.o
“_XCreatePixmap”, referenced from:
_Nviz_create_render_window in render.o
“_XFree”, referenced from:
“_XFreePixmap”, referenced from:
“_XOpenDisplay”, referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make: *** [/Users/epi/dev/grass7_trunk/dist.x86_64-apple-darwin13.1.0/lib/libgrass_nviz.7.1.svn.dylib] Error 1
MacBook-Pro-di-Massimo-2:~ epi$ file /opt/X11/lib/libGL.dylib
/opt/X11/lib/libGL.dylib: Mach-O universal binary with 2 architectures
/opt/X11/lib/libGL.dylib (for architecture i386): Mach-O dynamically linked shared library i386
/opt/X11/lib/libGL.dylib (for architecture x86_64): Mach-O 64-bit dynamically linked shared library x86_64
This looks like a problem to link wxWidgets (the C++ library, not the Python binding wxPython).
i fixed this adding a sim. link in use/local
ln -s /usr/local/Cellar/wxmac/3.0.0.0/lib/libwx_osx_cocoau-3.0.0.0.0.dylib /usr/local/lib/
This the log from :
g.gui gui=wxpython
raise err
This is probably caused by the fact that compilation for gui/wxpython/xml failed. I secretly hoped that this will be improved by r59485, are you using that version? The workaround used before was delete dist…/etc/gui/wxpython/xml and then run compilation of gui/wxpython inside GRASS session.
thanks! i followed this procedure, now the gui starts :slight_smile: and it is usable.
a problem witth Wx font already reported previously :
http://lists.osgeo.org/pipermail/grass-dev/2013-December/066536.html
is still here, i have this log printed in the shell all the time i use the gui :
2014-04-02 23:31:51.720 Python[78021:d07] CoreText performance note: Client called CTFontCreateWithName() using name “.Lucida Grande UI” and got font with PostScript name “.LucidaGrandeUI”. For best performance, only use PostScript names when calling this API.
i know it is a known problem,
http://forums.wxwidgets.org/viewtopic.php?f=23&t=38311
i hoped it was a 2.9 bug … while it still here with wx3.0
https://trac.osgeo.org/grass/changeset/59485 (modify Rules.make to fix build_modules_xml.py on Windows (TODO: replace this workaround))
http://lists.osgeo.org/pipermail/grass-dev/2014-March/067876.html (get interface description for python modules on Windows)
This is actually standard behavior. Probably not documented well. This is how g.region parameters are handled. Use g.region --ui.
i was aware that’s the standard behavior, but i found it a bit incoherent compared with what the other modules do.
Is there any reason for that ?
thanks!
Massimo.
Micha Silver
GIS Consulting
052-3665918
That�s correct, for some reason seems that it doesn�t detect the right architecture :
The configure script doesn't attempt to detect the architecture. The
default is --with-opengl=yes, which is equivalent to --with-opengl=x11.
For MacOSX, you need to use --with-opengl=mac (any of mac, macosx,
osx, aqua and agl will work).
If you think it is wrong or badly documented, you should open separate
thread for it and not confuse it compilation issues. If you decide to do
so, do a mailing list and Trac issues search beforehand.
