[GRASS-dev] compiling gdal-grass plugin with GRASS 7.0
I am trying to compile the gdal-grass plugin with GRASS 7.0, using:
./configure --with-gdal=/usr/local/gdal1.9/bin/gdal-config --with-grass=/usr/local/grass7/grass-7.0.svn
However, I am getting the error message that
“configure: error: --with-grass=/usr/local/grass7/grass-7.0.svn requested, but libraries not found! Perhaps you need to set LD_LIBRARY_PATH to include /usr/local/grass7/grass-7.0.svn/lib?”
I have set the library path though, using the below
echo “/usr/local/grass7/grass-7.0.svn/lib” > grass7.conf
sudo mv grass7.conf /etc/ld.so.conf.d
cd /etc/ld.so.conf.d
sudo ldconfig
Also, when configuring with grass6.4:
./configure --with-gdal=/usr/local/gdal1.9/bin/gdal-config --with-grass=/usr/local/grass6.4/grass-6.4.2svn
the gdal-grass plugin compiles without problems.
Rgds,
Paulo
On Tue, Apr 24, 2012 at 11:14 AM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
I guess that GDAL is not ready for GRASS 7. There is a ticket
for that which has been closed (wrongly IMHO):
http://trac.osgeo.org/gdal/ticket/2953
Perhaps that gives some insights.
Same problem here, I was trying to close a ticket about this and seems that it is not possible at this moment...
https://bugzilla.novell.com/show_bug.cgi?id=723890
I agree that gdal ticket should be reopened.
Angelos
grass-dev mailing list
grass-dev@lists.osgeo.org
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
