Hi
I am trying to compile GRASS 7 from svn on OS X El Capitan. I have
checked it uot using
--8<---------------cut here---------------start------------->8---
svn checkout https://svn.osgeo.org/grass/grass/trunk grass7_trunk
--8<---------------cut here---------------end--------------->8---
and have used the following configure options:
export LDFLAGS='-L/usr/local/lib -L/usr/local/opt/sqlite/lib'
export CPPFLAGS=I/usr/local/include -I/usr/local/opt/sqlite/include'
./configure --with-opengl=aqua --with-freetype=no --with-cxx --with-sqlite --prefix=/Applications --enable-macosx-app
This configures fine with the following result:
| GRASS is now configured for: x86_64-apple-darwin15.2.0
| Source directory: /Users/rainerkrug/ownCompiled/grass/grass7_trunk
| Build directory: /Users/rainerkrug/ownCompiled/grass/grass7_trunk
| Installation directory: ${prefix}/GRASS-7.1.app/Contents/MacOS
| Startup script in directory:${exec_prefix}/bin
| C compiler: gcc -g -O2
| C++ compiler: c++ -g -O2
| Building shared libraries: yes
| OpenGL platform: Aqua
| MacOSX application: yes
| MacOSX architectures:
| MacOSX SDK:
| BLAS support: no
| BZIP2 support: no
| C++ support: yes
| Cairo support: yes
| DWG support: no
| FFTW support: yes
| FreeType support: no
| GDAL support: yes
| GEOS support: no
| LAPACK support: no
| Large File support (LFS): yes
| libLAS support: no
| MySQL support: no
| NetCDF support: no
| NLS support: no
| ODBC support: no
| OGR support: yes
| OpenCL support: no
| OpenGL support: yes
| OpenMP support: no
| PDAL support: no
| PNG support: yes
| POSIX thread support: no
| PostgreSQL support: no
| Readline support: no
| Regex support: yes
| SQLite support: yes
| TIFF support: yes
| X11 support: no
But I get the following error messages when I compile using
make
| GRASS GIS 7.1.svn r67499 compilation log
| Started compilation: Wed Jan 6 15:46:25 CET 2016
| Errors in:
| /Users/rainerkrug/ownCompiled/grass/grass7_trunk/scripts/d.correlate
| /Users/rainerkrug/ownCompiled/grass/grass7_trunk/scripts/d.frame
| /Users/rainerkrug/ownCompiled/grass/grass7_trunk/scripts/d.out.file
| /Users/rainerkrug/ownCompiled/grass/grass7_trunk/scripts/d.to.rast
| /Users/rainerkrug/ownCompiled/grass/grass7_trunk/scripts/d.polar
Running make in
gives me the following output:
| 5:37:13 ~/ownCompiled/grass/grass7_trunk/scripts/d.correlate$ make
| if [ "/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts/d.correlate" != "" ] ; then GISRC=/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/demolocation/.grassrc71 GISBASE=/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0 PATH="/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts:$PATH" PYTHONPATH="/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/etc/python:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/gui/wxpython:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/lib:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/lib:" LC_ALL=C /Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts/d.correlate --html-description < /dev/null | grep -v '</body>\|</html>' > d.correlate.tmp.html ; fi
| dyld: Library not loaded: /Applications/GRASS-7.1.app/Contents/MacOS/lib/libgrass_gis.7.1.svn.dylib
| Referenced from: /Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin/g.parser
| Reason: image not found
| make: *** [d.correlate.tmp.html] Error 1
| rm d.correlate.tmp.html
What irritates me is the error message concerning not being able to
load - which is obvious, as I am still compiling GRASS and haven't
installed it yet.
The file is in
Any suggestions what is going on here?
grass71 compiles fine and I can launch it, but the
I am now trying it with
export CPPFLAGS='-I/usr/local/include -I/usr/local/opt/sqlite/include'
./configure --with-opengl=aqua --with-freetype=no --with-cxx --with-sqlite --prefix=~/ownCompiled/
which results in
| Installation directory: ${prefix}/grass-7.1.svn
| MacOSX application: no
| MacOSX SDK:
| BLAS support: no
| BZIP2 support: no
| C++ support: yes
| Cairo support: yes
| DWG support: no
| FFTW support: yes
| GDAL support: yes
| GEOS support: no
| LAPACK support: no
| libLAS support: no
| MySQL support: no
| NetCDF support: no
| NLS support: no
| ODBC support: no
| OGR support: yes
| OpenCL support: no
| OpenGL support: yes
| OpenMP support: no
| PDAL support: no
| PNG support: yes
| Regex support: yes
| SQLite support: yes
| TIFF support: yes
| X11 support: no
make -j 8
results in many errors, where the first one is in d.frame, where, when
compiling from there, I get
| 05:49:58 ~/ownCompiled/grass/grass7_trunk/scripts/d.frame$ make
| if [ "/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts/d.frame" != "" ] ; then GISRC=/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/demolocation/.grassrc71 GISBASE=/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0 PATH="/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts:$PATH" PYTHONPATH="/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/etc/python:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/gui/wxpython:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/bin:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/lib:/Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/lib:" LC_ALL=C /Users/rainerkrug/ownCompiled/grass/grass7_trunk/dist.x86_64-apple-darwin15.2.0/scripts/d.frame --html-description < /dev/null | grep -v '</body>\|</html>' > d.frame.tmp.html ; fi
| dyld: Library not loaded: /Users/rainerkrug/ownCompiled//grass-7.1.svn/lib/libgrass_gis.7.1.svn.dylib
| make: *** [d.frame.tmp.html] Error 1
| rm d.frame.tmp.html
| 05:50:00 ~/ownCompiled/grass/grass7_trunk/scripts/d.frame$
So the same.
What is going on here? Why is it trying to load during compilation a
dynamic library from a location where it will be installed *after* it
has been compiled?
Any help appreciated,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
