i am using ubuntu 8.10. I have downloaded grass 6.2.3 source code. I referred the INSTAL file and installed all pre requisites. I am trying to compile the source code now. But when i enter the command ‘make’, it says, Makefile:22: include/Make/Platform.make: No such file or directory Makefile:23: include/Make/Grass.make: No such file or directory make: *** No rule to make target `include/Make/Grass.make’. Stop. Please provide me step by step details on how to compile the source code.
View this message in context: Compiling GRASS on Ubuntu
Sent from the Grass - Dev mailing list archive at Nabble.com.
dasuni kannangara wrote:
i am using ubuntu 8.10. I have downloaded grass 6.2.3 source code. I referred the INSTAL file and installed all pre requisites. I am trying to compile the source code now. But when i enter the command 'make', it says,
make: *** No rule to make target `include/Make/Grass.make'. Stop.
Have you configured the source code first with ./configure? See also (B) COMPILATION in the INSTALL file.
1. get source code for grass-6.4.0RC3, this version is much better than grass-6.2.3
2. run ./configure within the directory grass-6.4.0RC3 with your choice of configuration options, optionally first ./configure --help to see configuration options
3. only now can you 'make' grass
see also grass wiki on compile and install [1]
[1] http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu
Thanks Markus. i followed the instructions, still am getting the same result. I have attached a screen shot of the console. Please refer it and please reply what i can do to compile the codes properly.console
Markus Metz-2 wrote:
dasuni kannangara wrote: > i am using ubuntu 8.10. I have downloaded grass 6.2.3 source code. I referred the INSTAL file and installed all pre requisites. I am trying to compile the source code now. But when i enter the command ‘make’, it says, > > Makefile:22: include/Make/Platform.make: No such file or directory > Makefile:23: include/Make/Grass.make: No such file or directory > make: *** No rule to make target `include/Make/Grass.make’. Stop. > Have you configured the source code first with ./configure? See also (B) COMPILATION in the INSTALL file. > Please provide me step by step details on how to compile the source code. > 1. get source code for grass-6.4.0RC3, this version is much better than grass-6.2.3 2. run ./configure within the directory grass-6.4.0RC3 with your choice of configuration options, optionally first ./configure --help to see configuration options 3. only now can you ‘make’ grass see also grass wiki on compile and install [1] [1] http://grass.osgeo.org/wiki/Compile_and_Install#Ubuntu _______________________________________________ grass-dev mailing list grass-dev@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-dev
View this message in context: Re: Compiling GRASS on Ubuntu
On Wed, Apr 8, 2009 at 11:29 AM, dasuni kannangara <dasuni7@gmail.com> wrote:
When you execute ./configure, look out for error messages. In your
case, configure quits with an error message:
configure: error: *** Unable to locate lex
in your case, you have to install lex
Make sure that you have all dependencies (and the dev packages!) installed.
Rainer
command 'make', it says, > > Makefile:22: include/Make/Platform.make: No
or directory > make: *** No rule to make target `include/Make/Grass.make'.
configuration options 3. only now can you 'make' grass see also grass wiki
Rainer M. Krug, Centre of Excellence for Invasion Biology,
Stellenbosch University, South Africa
To make this easier on any Debian-derived system (such as Ubuntu) you can run
apt-get build-dep grass
first in order to install all build dependencies.
You can also do this:
apt-get source grass
to get the source code of the ubuntu grass package, then copy the debian/ folder in that source code into the more recent source code you downloaded from the GRASS site and then run 'fakeroot dpkg-buildpackage' in the root directory of the source code.
You are aware that there are fairly recent grass packages for Ubuntu available here:
http://les-ejk.cz/ubuntu/
Moritz
Thanks a lot. I could install all dependencies and successfully compiled GRASS source code. I got some errors on nviz and i solved those too. somehow, through console i compiled the code. but after that, i opened the codes in eclipse (whole project). when i tried to build the project, i got 21 errors from main.c file in visualization/ximgview folder. I cant figure out the reasons. i have attached a screenshot of those too. Please tell me how i can solve those.
