hi,
in [1], I've updated the instructions to compile GRASS on windows platforms.
compilation steps based upon the both frameworks OSGeo4W and MSYS2 are
straightforward; the list of mentioned dependencies are up-to-date.
producing VC libraries using dumpbin command is one of the compilation/build
steps on windows. as MS Visual Studio and its $PATH/folder structure is a
some kind of a moving window, there are now examples in the instructions
related to older and newer MS Visual Studio versions.
testing and feedback welcome.
[1] https://trac.osgeo.org/grass/wiki/CompileOnWindows
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
