[GRASS-dev] Compiling GRASS with PROJ 5.0.0
according to [1] it seems a new proj.4 version, now called PROJ 5.0.0, will
be out in the beginning of March.
anyone already tried to compile GRASS with PROJ 5.0.0 RC?
[1] http://lists.maptools.org/pipermail/proj/2018-February/007990.html
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
Yes, 7.4.0 builds fine, see:
https://lists.debian.org/debian-gis/2018/02/msg00006.html
I have not tested if everything still works. There may be issues in the
API like the one that caused the postgis tests to fail, see:
https://trac.osgeo.org/postgis/ticket/4016
https://github.com/OSGeo/proj.4/pull/808
Kind Regards,
Bas
