[GRASS-dev] compiling i.pr: error: ogr_api.h: No such file or directory
Hello,
Trying to compile i.pr from the GRASS Add-Ons, I get the following error:
make[1]: Entering directory `/home/mlennert/SRC/GRASS/i.pr/i.pr_sites_aggregate'
gcc -I/home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/include -Wall -g -O2 -I../include/ -DPACKAGE=\""grassmods"\" -I/home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/include -o OBJ.i486-pc-linux-gnu/main.o -c main.c
In file included from /home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/include/grass/vect/digit.h:3,
                  from /home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/include/grass/Vect.h:4,
                  from main.c:6:
/home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/include/grass/vect/dig_structs.h:22:21: error: ogr_api.h: No such file or directory
                  from main.c:6:
/home/mlennert/SRC/GRASS/grass6/dist.i486-pc-linux-gnu/include/grass/vect/dig_structs.h:170: error: expected specifier-qualifier-list before 'OGRDataSourceH'
main.c: In function 'main':
main.c:90: warning: value computed is not used
main.c:93: warning: value computed is not used
make[1]: *** [OBJ.i486-pc-linux-gnu/main.o] Error 1
make[1]: Leaving directory `/home/mlennert/SRC/GRASS/i.pr/i.pr_sites_aggregate'
'locate ogr_api.h' gives:
/usr/include/gdal/ogr_api.h
The relevant lines in include/grass/vect/dig_structs.h are
#ifdef HAVE_OGR
#include "ogr_api.h"
#endif
When I change this to
#include "gdal/ogr_api.h"
it compiles correctly.
Is this a bug in grass, i.e. should this be gdal/ogr_api.h in the headers file ?
Moritz
                  from
                  from main.c:6:
                  from
                  from main.c:6:
#ifdef HAVE_OGR
#endif
Strange. Does ogr_api.h use the "gdal/" prefix in headers which it
includes? What does "gdal-config --cflags" say?
I think that it's a bug in i.pr.
No; "gdal" is not part of the header name, at least not in the version
I have (1.3.1). Headers don't use that to refer to themselves.
Modules which include vector headers need to have:
  EXTRA_CFLAGS = $(VECT_CFLAGS)
in their Makefile. i.pr would appear to have omitted this.
                  from main.c:6:
                  from main.c:6:
#ifdef HAVE_OGR
#endif
includes?
No
$ gdal-config --cflags
-I/usr/include/gdal
Yes, that was it. Thanks.
Moritz
