[GRASS-dev] compiling in debian 8 fails in r.sunmask and r.support
hi,
fresh svn up and make clean, any idea why compilations may fail:
Started compilation: Fr 23. Feb 16:55:33 CET 2018
Errors in:
/home/bugs/dev/cpp/grass7_trunk/raster/r.sunmask
/home/bugs/dev/cpp/grass7_trunk/raster/r.support
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fr 23. Feb 17:08:15 CET 2018
Makefile:57: die Regel für Ziel „default“ scheiterte
make: *** [default] Fehler 1
bugs@nada:~/dev/cpp/grass7_trunk$ cd raster/r.sun
r.sun/ r.sunhours/ r.sunmask/
bugs@nada:~/dev/cpp/grass7_trunk$ cd raster/r.sunmask/
bugs@nada:~/dev/cpp/grass7_trunk/raster/r.sunmask$ make
if [
"/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.sunmask" !=
"" ] ; then
GISRC=/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/demolocation/.grassrc75
GISBASE=/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu
PATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/python:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/scripts:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/lib:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/lib:"
LC_ALL=C LANG=C LANGUAGE=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.sunmask.tmp.html ; fi
/bin/sh: 1:
/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.sunmask:
Permission denied
../../include/Make/Html.make:14: die Regel für Ziel „r.sunmask.tmp.html“
scheiterte
make: *** [r.sunmask.tmp.html] Fehler 1
rm r.sunmask.tmp.html
bugs@nada:~/dev/cpp/grass7_trunk/raster/r.sunmask$ cd ..
bugs@nada:~/dev/cpp/grass7_trunk/raster$ cd r.support
bugs@nada:~/dev/cpp/grass7_trunk/raster/r.support$ make
if [
"/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.support" !=
"" ] ; then
r.support.tmp.html ; fi
/bin/sh: 1:
/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.support:
Permission denied
../../include/Make/Html.make:14: die Regel für Ziel „r.support.tmp.html“
scheiterte
make: *** [r.support.tmp.html] Fehler 1
rm r.support.tmp.html
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
Helmut Kudrnovsky wrote
hi,
Errors in:
'make'.
if [
"" ] ; then
</body>
</html>
/bin/sh: 1:
Permission denied
scheiterte
if [
"" ] ; then
</body>
</html>
/bin/sh: 1:
Permission denied
scheiterte
best regards
Helmut
grass-dev mailing list
grass-dev@.osgeo
https://lists.osgeo.org/mailman/listinfo/grass-dev
sorry for the noise, a second make clean/make distclean helped; compiling
now without an issue
best regards
Helmut
