On Sat, 12. Feb 2011 at 19:05:31 +0100, Helmut Kudrnovsky wrote:
c:/OSGeo4W/include/io.h:41: error: redefinition of typedef 'intptr_t'
Where is that io.h from? I don't have one - so it's probably not from
osgeo4w.
no idea?
the content of io.h is
* io.h
* This file has no copyright assigned and is placed in the Public Domain.
* This file is a part of the mingw-runtime package.
* No warranty is given; refer to the file DISCLAIMER within the package.
* System level I/O functions and types.
#ifndef _IO_H_
#define _IO_H_
/* All the headers include this file. */
#include <_mingw.h>
/* MSVC's io.h contains the stuff from dir.h, so I will too.
* NOTE: This also defines off_t, the file offset type, through
* an inclusion of sys/types.h */
#include <sys/types.h> /* To get time_t. */
* Attributes of files as returned by _findfirst et al.
#define _A_NORMAL 0x00000000
#define _A_RDONLY 0x00000001
#define _A_HIDDEN 0x00000002
#define _A_SYSTEM 0x00000004
#define _A_VOLID 0x00000008
#define _A_SUBDIR 0x00000010
#define _A_ARCH 0x00000020
#ifndef RC_INVOKED
#ifndef _INTPTR_T_DEFINED
#define _INTPTR_T_DEFINED
#ifdef _WIN64
typedef __int64 intptr_t;
#else
typedef int intptr_t;
#endif
#endif
#ifndef _FSIZE_T_DEFINED
typedef unsigned long _fsize_t;
#define _FSIZE_T_DEFINED
#endif
* The maximum length of a file name. You should use GetVolumeInformation
* instead of this constant. But hey, this works.
* Also defined in stdio.h.
#ifndef FILENAME_MAX
#define FILENAME_MAX (260)
#endif
* The following structure is filled in by _findfirst or _findnext when
* they succeed in finding a match.
struct _finddata_t
unsigned attrib; /* Attributes, see constants above. */
time_t time_create;
time_t time_access; /* always midnight local time */
time_t time_write;
_fsize_t size;
char name[FILENAME_MAX]; /* may include spaces. */
struct _finddatai64_t {
unsigned attrib;
time_t time_create;
time_t time_access;
time_t time_write;
__int64 size;
should I rename it and try again?
Helmut
___________________________________________________________
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://produkte.web.de/go/webdefreephone
