[GRASS-dev] computational geometry in C++ library
Dear GRASS developers,
I just found a site concerning geometric algorithms (GPL):
easy access to useful, reliable geometric algorithms
The CGAL library contains:
     * the Kernel with geometric primitives such as points, vectors, lines, predicates for testing things such as relative positions of points, and operations such as intersections and distance calculation.
     * the Basic Library which is a collection of standard data structures and geometric algorithms, such as convex hull in 2D/3D, (Delaunay) triangulation in 2D/3D, planar map, polyhedron, smallest enclosing circle, and multidimensional query structures.
     * the Support Library which offers interfaces to other packages, e.g., for visualisation, and I/O, and other support facilities.
you may already know this site but in case you don't it might be worth a look.
I know that GRASS is ANSI-C and these libraries are C++ but perhaps some problem can be solved using these libraries.
http://www.cgal.org/index2.html
regards, Martin
It would be fantastic to have a version of this library
in GRASS 6.1.
I could think of a dozen generally useful GRASS modules
based on this: 3D convex hull, converting 3D polygons to voxels,
point in 3D polygon queries ...
I don't know much C++, but surely there
must be a way to use the methods in this library with
standard C function calls? Some sort of simple wrapper perhaps?
Benjamin
regards, Martin
grass-dev mailing list
grass-dev@grass.itc.it
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeo-Information Science)
Institut für Ur- und Frühgeschichte
(Institute of Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
in GRASS 6.1.
Calling C funcs from C++ is straight-forward.
The reverse is not possible, the whole result would be a C++ prog.
Francesco P. Lovergine
> in GRASS 6.1.
It's not quite that bad. You can write C-callable wrapper functions in
C++, e.g.:
  extern "C" {
  void wrapper(void *p)
    ((Object *) p)->method();
Note that the GLU library is written in C++, but can be used from C
programs.
C++, e.g.:
  extern "C" {
programs.
Oh, yes, but that's C++, isn't it? The resulting code will link C++
objects with all consequent headaches (e.g. obscure ABI changes from
time to time) and C++ run-time on the shoulder.
That's what I pointed with my first sentence, C code can be called
by C++, but not viceversa.
> C++, e.g.:
> extern "C" {
> programs.
Yes.
Er, the above is C++, but it can be called from C.
GRASS code should avoid using C++ where possible, but we already
depend upon some libraries which are written in C++, most notably
GDAL, which is a mandatory dependency in 6.x.
If there's a particularly useful third-party library, we shouldn't
ignore it just because it is written in C++. However, anything which
uses it should first create a set of C wrappers (if the the library
doesn't already provide them) and use those, rather than using the C++
interface directly. If more than one module uses the library, the C
interface should either be made into a library or, where possible,
contributed back for inclusion into the original library.
Does this mean, the next release of GRASS is intended to ship with a
version of GDAL included?
This would be a blessing for people tired of the circular GRASS and
GDAL recompile game.
I searched the web quickly and there does not seem to be any C wrappers
for CGAL yet. It's a fairly complex library, but maybe the most
important bits wouldn't be so hard to wrap ...
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
No. It is too much work to keep all dependencies in sync and up to date.
This is a job for packagers to take care of, the source code must stay
generic.
For this there is the GDAL-GRASS plugin,
http://www.gdal.org/dl/gdal-grass-1.3.1.2.tar.gz
Hamish
