[GRASS-dev] configuring grass 6.3 for cross compilation
dear GRASS developers,
I am trying to cross-compile GRASS 6.3.cvs using Radim's instructions
on this page: http://wiki.qgis.org/qgiswiki/BuildingWindowsBinaryOnLinux
However, configure aborts with:
checking for proj_api.h... yes
configure: warning: *** Cannot check PROJ.4 version (cross-compiling).
checking for location of External PROJ.4 library...
checking for pj_get_def in -lproj... yes
checking for location of External PROJ.4 data files...
configure: warning: *** External PROJ.4 directory not specified
checking for /epsg... configure: error: Cannot check for file existence
when cross compiling
This did not happen with a 6.1 cvs version.
Are there any updates on how to configure 6.3 for cross compilation?
Any help will be greatly appreciated!
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
Right now, you can't. I'm looking into a fix, but until then you'll
need to manually remove the check from the configure script.
I've committed a change to the configure script which should fix this,
although I don't a cross-compilation environment to check it.
Ok, it works now. Thanks, Glynn.
Archäoinformatik
D 24098 Kiel
Germany
www.uni-kiel.de/ufg
