[GRASS-dev] Consistency in raster file's history produced with t.rast.series
The following works just fine:
t.rast.series ols output=ols_max method=maximum
But the history isn't exactly consistent:
r.info ols_max -h
Data Description:
    generated by r.series
Comments:
    r.series -z file="/geo/grassdb/ols/sicily/.tmp/tpx1c2g/22707.0" outp\
    ut="ols_max" method="maximum"
Why not record that the raster map in question was produced by t.rast.series? Is it not desired?
Thank you, Nikos
Hi Nikos,
2015-02-18 10:36 GMT+01:00 Nikos Alexandris <nik@nikosalexandris.net>:
r.info ols_max -h
Data Description:
Comments:
It is not implemented and i have no plan to do so.
Only temporal datatypes (STDS) will have their own temporal framework
specific command history. Several temporal modules are simple wrapper
around existing spatial modules, hence the command history will
reflect the wrapped module calls.
Best regards
Soeren
Thank you, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
Thanks for the feedback Soeren,
Nikos
On 18.02.2015 11:42, Sören Gebbert wrote:
Hi Nikos,
r.info ols_max -h
Data Description:
Comments:
Best regards
Soeren
