With the migration to GitHub, what exactly is the process for making contributions to the addons repository? Some of the documentation still covers SVN rather than git. Can I directly pull, commit, and push from master or should I make a branch and then submit a pull request?
Thanks, Brendan
Brendan <brendan.harmon@gmail.com> schrieb am Mo., 30. Dez. 2019, 21:27:
Please fork, edit/add and make pull requests.
Ok that should be updated accordingly.
Which docs do you refer to?
A PR is the preferred way.
If it is your own code you can also merge right away. If it is other author’s code, some feedback might be fair to be obtained (via PR) but it also depends a bit on the case.
HTH, my 0.02 cents,
Thanks, Brendan
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Thanks. Got it.
Documentation with old instructions includes:
How to Contribute
https://trac.osgeo.org/grass/wiki/HowToContribute#SettingupthenewSVNwriteaccessafteracceptance
Submittinghttps://trac.osgeo.org/grass/wiki/Submitting#GRASSGISAddons
https://trac.osgeo.org/grass/wiki/Submitting#SubmittingcodetoSVN
How to SVN
https://trac.osgeo.org/grass/wiki/HowToSVN
The GitHub GRASS Addons repo contains SVN_HOWTO.txt
rather than a git HOWTO like https://trac.osgeo.org/grass/wiki/HowToGit
I think a link in the README to https://trac.osgeo.org/grass/wiki/HowToGit would help.
Submitting Python Code
https://trac.osgeo.org/grass/wiki/Submitting/Python
mentions svn diff which could be updated to git diff
I believe there was a discussion on the grass-dev list about using Python Black for style.
Was there a decision? That could be added to this wiki page.
-Brendan
On Mon, Dec 30, 2019 at 3:04 PM Markus Neteler <neteler@osgeo.org> wrote:
Which docs do you refer to?Can I directly pull, commit, and push from master or should I make a branch and then submit a pull request?
If it is your own code you can also merge right away. If it is other author’s code, some feedback might be fair to be obtained (via PR) but it also depends a bit on the case.HTH, my 0.02 cents,
Thanks, Brendan
Sorry for the late reply.
On Tue, Dec 31, 2019 at 12:03 AM Brendan <brendan.harmon@gmail.com> wrote:
Thanks. Got it.
How to Contribute
... yes, that needs to be done.
Submitting
... updated to "Submitting code to GitHub".
How to SVN
... marked as "historic" with link to new page.
... deleted.
... yes, deduplication is the best.
...done.
AFAIK no decision. It might be good to come back to this discussion.
Thanks for the links!
