I have been trying to use i.pr addon module in GRASS6.4 but Markus explained to me that this addon was developed for GRASS5. So, if I wanted to use in GRASS6 I would have to "covert" to GRASS6.I want to know where can I find some documentation regarding the conversion from GRASS5 to GRASS6 and what are the main differences. With this I will evaluate the effort I will need to convert a module from GRASS5 to GRASS6
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5040 (20100419) __________
for an imagery (raster) module, maybe it is as simple as writing a new
Makefile? (start with a copy from something similar)
the raster format and display drivers didn't really change between 5 and 6.
I'm note sure the issue is only with Makefiles. See
I believe the module compilation was ok. The problem is opening/displaying images in panel (monitor) using d.mon X0 and then i.pr.training command.
I decided to sleep over this matter and today, I realized that it makes sense. The thing is i.pr.training is compiling but in the panel the rasters are not being displayed. Maybe some library it's not working. I will give a try
Is there any wiki regarding library changes from GRASS5 to GRASS6?
Thanks
Antonio
