[GRASS-dev] Copying Landsat MTL file(s) inside the cell_misc directory -- Python scripting
Dear list,
whose creation is the the import_landsat.py script featured in
<http://grasswiki.osgeo.org/wiki/LANDSAT#Automated_data_import&gt;?
I would like to expand it a bit in copying the respective metadata (*MTL.txt)
files over to the (respective) "cell_misc" directory? I guess that using the
"shutil" is the way to go, like:
# in the beginning
import shutil
# later on... but where?
env=grass.gisenv()
shutil.copy ( metafile, env['GISDBASE'] + '/' + env['LOCATION_NAME'] + '/' +
env['MAPSET'] + '/cell_misc')
Is that correct? It seems it works interactively. I am ignorant, however,
about where to insert the above instructions. I wrongly tried within the
"import_tifs()" function, inside the 1st for loop, right after the
creation of
a Mapset of interest.
Thanks for any hints, Nikos
This question is still valid :-). If my 2 proposed changes don't do something
seriously wrong, I would like to update the script in the wiki.
(*MTL.txt) files over to the (respective) "cell_misc" directory? I guess
that using the "shutil" is the way to go, like:
1) I managed to integrate another small function (thanks to Luca D for off-
list support), actually a clone of one small function already found in the
script. It works like:
def copy_metafile(mapset):
    # get the metafile
    try:
        metafile = glob.glob(mapset + '/*MTL.txt')[0]
        print '\nThe identified metadata file is:\n %s\n' %
metafile.split('/')[1]
    except IndexError:
        return
    # get environment variables & define path to "cell_misc"
    gisenv=grass.gisenv()
    CELL_MISC_DIR = gisenv['GISDBASE'] + '/' + gisenv['LOCATION_NAME'] + '/' +
gisenv['MAPSET'] + '/cell_misc'
    print 'The identified metadata file will be copied at:\n %s\n' %
CELL_MISC_DIR
    # copy the metadata file
    shutil.copy (metafile, CELL_MISC_DIR)
I call this small function in the end of the "core" function
"import_tifs(mapset)" to copy the MTL file in the respective "cell_misc"
directory, i.e.:
2) The current script checks inside the MTL file for the string
'ACQUISITION_DATE' to get the date of acquisition. The code (lines 56-57) goes
like:
    if 'ACQUISITION_DATE' in line:
        result['date'] = line.strip().split('=')[1].strip()
Since newer MTL files contain the string 'DATE_ACQUIRED', another check is
required. The script certainly works by adding an extra if statement, like:
    if 'DATE_ACQUIRED' in line:
Nevertheless, I want to merge the two "if" statements in one. So, my attempt
goes like
    if 'DATE_ACQUIRED' or 'ACQUISITION_DATE' in line:
This is wrong. I have no idea, though, on why the former "simple" if
statements return a single line, while the latter if statement, which contains
the "or" operator, does return the complete MTL file content!
And, finally, the following works:
    if 'DATE_ACQUIRED' in line or 'ACQUISITION_DATE' in line:
I know the following is a pure python question -- still, can someone shed some
light on why is there such a difference between
and
Thanks, Nikos
Hi Nikos,
On Tue, May 14, 2013 at 1:25 PM, Nikos Alexandris
and
Your error is due to the precedence of the operator, what it is really
written in the first row is:
if ( ('DATE_ACQUIRED') or ('ACQUISITION_DATE' in line) ):
Therefore the first statement 'DATE_ACQUIRED' is always True because
is a string that it is not empty.
Let me define a function like:
def istrue(obj):
... if obj:
... return True
... return False
Now If you try with an empty string you have:
istrue('')
False
If you try with a string that contains something you get:
istrue('DATE_ACQUIRED')
True
Therefore the second is correct because you check if the first string
is contained or the second string is contained in the line.
An easy way to debug this kind of problems is to use python debugger
[1] (possibly the ipython dubugger! [2]) in the line before, like:
import ipdb; ipdb.set_trace() # or import pdb; pdb.set_trace()
# set_trace will open a terminal to debug your program from this point...
[etc]
Have fun with python! :slight_smile:
All the best.
Pietro
[0] http://www.isthe.com/chongo/tech/comp/c/c-precedence.html
[1] http://docs.python.org/2/library/pdb.html
[2] https://pypi.python.org/pypi/ipdb
Hi Pietro,
thank you for taking the time to clarify this -- Perfect!
Note to self: use parentheses in complex if statements (and not only!).
Nikos
On Tuesday 14 of May 2013 14:43:55 Pietro wrote:
Hi Nikos,
> some light on why is there such a difference between
> and
>>> def istrue(obj):
... if obj:
... return True
... return False
>>> istrue('')
False
True
[etc]
All the best.
Pietro
> and
It's not just the precedence, but also the semantics of the "or" and
"in" operators. If the first expression had been parenthesised
according to the presumed intent of the expression, i.e.:
  if ('DATE_ACQUIRED' or 'ACQUISITION_DATE') in line:
the result would have been equivalent to:
as the "or" operator returns the first argument if it is considered
true and the second argument otherwise. As all non-empty strings are
considered true, the "or" operator would have simply returned the
left-hand string, which would be used as the argument to the "in"
operator.
In general: False, None, 0, 0.0, the empty string and any empty
container (list, tuple, set, dictionary) are considered false, while
most other values are considered true (classes can customise their
behaviour by defining __nonzero__ or __len__ methods).
The "in" operator uses the __contains__ method of the right-hand
argument, i.e. "x in y" evalutes "y.__contains__(x)". For lists,
tuples and sets, "x in y" is true if x is an element of the list or
set; for dictionaries, "x in y" is true if x is a key in the
dictionary y. For strings, the expression is true if the left-hand
argument is a substring of the right-hand argument.
If you want to find out whether any one of a number of candidates are
contained within an object, you need to explicitly iterate over them,
e.g.:
  if any(x in line for x in ('DATE_ACQUIRED', 'ACQUISITION_DATE')):
> > shed some light on why is there such a difference between
> > and
operator.
This explains why time-stamping did not work correctly, in the script
mentioned in the first post of this thread, when parsing an old(er) Landsat
metadata file (i.e. LE71610762013070PFS00_MTLold.txt which contains the string
'ACQUISITION_DATE').
e.g.:
Works with any MTL file now, i.e. with both the LE71610762013070PFS00_MTL.txt
and the old(er) LE71610762013070PFS00_MTLold.txt Landsat metadata files.
Thanks, Nikos
LE71610762013070PFS00_MTL.txt and the old(er)
I slightly modified the "import_landsat.py" script in the GRASS-Wiki:
to be aware about Landsat8 scenes. If there are no objections, I'd like to
"update" it. Here the modified version:
<http://grasswiki.osgeo.org/wiki/User:NikosA/Landsat&gt;\. Even better, are there
corrections?
Wouldn't a dedicated import script for Landsat products be useful? Like
r.in.aster for example -- though, maybe it would be better called
i.landsat.import?
Thanks, Nikos
Nikos
i.landsat.import?
see also r.in.modis
I think r.in.* is the correct pattern to follow.
regards,
Hamish
