I just tried to copy a vector file from within GRASS 7. The file is from a couple years back and uses a dbf data table. I got an odd error message.
g.copy vect=wind@baltic,wind
Copy vector <wind@baltic> to current mapset as <wind>
DBMI-SQLite driver error:
Error in sqlite3_step():
SQL logic error or missing database
Unable to create index for table <wind>, key <ID>
Any thoughts? I did compile GRASS 7 with sqlite.
Michael
Maybe it is necessary to rebuild topology for wind@baltic first before copying, because otherwise the database links can not be read because support files including dbln can not be opened. Maybe it is a good idea to let grass7 open and read database links even if other support files can not be opened (missing or unsupported version)?
Markus M
