When the user enters input to r.mapcalc non-interactively on the command line, the program will not warn the user not to overwrite existing map layers. Users should therefore take care to assign program outputs raster map names that do not yet exist in their current mapsets.
Perhaps the description is somewhat ambiguous, but if the way I read this is correct, this is not the default behaviour. Perhaps the following describes it better:
By default it is not possible to overwrite existing raster layers, so the user is expected to take care to assign program output raster names that do not yet exist in their current mapset. If they want to overwrite existing maps, users can use the --overwrite flag.
When the user enters input to /r.mapcalc/ non-interactively on the
current mapsets.
I added a patch file in case the above is ok.
This is a leftover from history. Old r.mapcalc did not use the parser in the same way and did not check whether the output file existed and just overwrote it. Since GRASS 7 this has changed.
However, I would suggest to just completely erase the part you want to replace. I don't think there is a need for your replacement. Otherwise we would have to add such a sentence to the manual of each module that creates output...
On February 23, 2017 18:20:18 Moritz Lennert <mlennert@club.worldonline.be> wrote:
On 23/02/17 15:33, Paulo van Breugel wrote:
Dear devs,
In the help file of r.mapcalc it is written:
current mapsets.
Yes, and a very good change it was
creates output...
