* ./display/d.barscale/main.c:171 [error] - Undefined behaviour: cmdbuf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.barscale/main.c:172 [error] - Undefined behaviour: cmdbuf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.profile/Range.c:27 [error] - Buffer access out-of-bounds: inbuf
* ./display/d.profile/Range.c:48 [error] - Resource leak: temp_file
* ./display/d.text.new/main.c:382 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.text.new/main.c:383 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.text.new/main.c:384 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.text.new/main.c:385 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.text.new/main.c:386 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.text.new/main.c:387 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.text.new/main.c:388 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.vect/label.c:97 [error] - Undefined behaviour: text is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.vect/label.c:99 [error] - Undefined behaviour: text is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.zoom/print.c:106 [error] - Undefined behaviour: buffer is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.zoom/print.c:113 [error] - Undefined behaviour: buffer is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./display/d.zoom/print.c:120 [error] - Undefined behaviour: buffer is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./gem/at_exit_funcs.c:103 [error] - Resource leak: dir
* ./gem/main.c:405 [error] - Buffer overrun possible for long cmd-line args
* ./gem/reg_entries.c:316 [error] - Resource leak: f_out
* ./gem/reg_entries.c:525 [error] - Resource leak: f_out
* ./gem/reg_entries.c:756 [error] - Resource leak: f_out
* ./gem/reg_html.c:228 [error] - Resource leak: f_out
* ./gem/reg_html.c:330 [error] - Resource leak: f_out
* ./gem/reg_html.c:440 [error] - Resource leak: f_out
* ./gem/tools.c:327 [error] - Memory leak: tmp
* ./gem/tools.c:460 [error] - Memory leak: tmp
* ./gem/tools.c:526 [error] - Memory leak: tmp
* ./gem/tools.c:683 [error] - Resource leak: dir
* ./gem/tools.c:719 [error] - Resource leak: dir
* ./gem/tools.c:823 [error] - Resource leak: f
* ./gui/wxpython/vdigit/pseudodc.cpp:150 [error] - Mismatching allocation and deallocation: gpdcDrawPolyPolygonOp::m_count
* ./imagery/i.atcorr/AerosolConcentration.cpp:35 [error] - Passing value 0 to log() leads to undefined result
* ./imagery/i.ortho.photo/photo.2image/ask.c:265 [error] - Resource leak: fd
* ./imagery/i.ortho.photo/photo.2target/ask.c:263 [error] - Resource leak: fd
* ./imagery/i.ortho.photo/photo.rectify/ps_cp.c:53 [error] - Uninitialized variable: msg
* ./imagery/i.ortho.photo/photo.rectify/ps_cp.c:58 [error] - Uninitialized variable: msg
* ./imagery/i.points/ask.c:264 [error] - Resource leak: fd
* ./imagery/i.vpoints/ask.c:260 [error] - Resource leak: fd
* ./lib/bitmap/bitmap.c:327 [error] - Memory leak: map
* ./lib/bitmap/bitmap.c:351 [error] - Memory leak: map.data
* ./lib/cairodriver/read_ppm.c:26 [error] - Resource leak: input
* ./lib/cdhc/enormp.c:51 [error] - Uninitialized variable: x4
* ./lib/dspf/cube_io.c:257 [error] - Buffer access out-of-bounds: in_buf
* ./lib/edit/edit_cellhd.c:558 [error] - fflush() called on input stream "stdin" may result in undefined behaviour
* ./lib/external/shapelib/shpopen.c:849 [error] - Memory leak: pszBasename
* ./lib/gis/copy_file.c:48 [error] - Resource leak: infp
* ./lib/gis/error.c:346 [error] - Resource leak: log
* ./lib/gis/gdal.c:58 [error] - Uninitialized variable: sym
* ./lib/gis/ls.c:114 [error] - Resource leak: dfd
* ./lib/iostream/mm.cc:304 [error] - Memory leak: p
* ./lib/iostream/mm.cc:355 [error] - Memory leak: p
* ./lib/nviz/render.c:122 [error] - Possible null pointer dereference: v - otherwise it is redundant to check if v is null at line 128
* ./lib/nviz/render.c:123 [error] - Possible null pointer dereference: v - otherwise it is redundant to check if v is null at line 128
* ./lib/ogsf/gv.c:184 [error] - Possible null pointer dereference: gv - otherwise it is redundant to check if gv is null at line 186
* ./lib/ogsf/gvl.c:188 [error] - Possible null pointer dereference: gvl - otherwise it is redundant to check if gvl is null at line 190
* ./lib/symbol/read.c:345 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./lib/symbol/read.c:429 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./lib/vask/V_exit.c:57 [error] - fflush() called on input stream "stdin" may result in undefined behaviour
* ./lib/vector/Vlib/dbcolumns.c:79 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./lib/vector/Vlib/dbcolumns.c:139 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./lib/vector/Vlib/dbcolumns.c:202 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./lib/vector/dglib/examples/opt.c:220 [error] - Memory leak: pszArgv
* ./raster/r.flow/precomp.c:154 [error] - Array index -1 is out of bounds
* ./raster/r.flow/precomp.c:158 [error] - Array index -1 is out of bounds
* ./raster/r.flow/precomp.c:161 [error] - Array index -1 is out of bounds
* ./raster/r.flow/precomp.c:163 [error] - Array index -1 is out of bounds
* ./raster/r.flow/precomp.c:165 [error] - Array index -1 is out of bounds
* ./raster/r.in.gridatb/file_io.c:64 [error] - Deallocating a deallocated pointer: fp
* ./raster/r.li/r.li.cwed/cwed.c:127 [error] - Resource leak: file_fd
* ./raster/r.li/r.li.cwed/cwed.c:333 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.cwed/cwed.c:476 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.cwed/cwed.c:612 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.daemon/daemon.c:282 [error] - Resource leak: res
* ./raster/r.li/r.li.daemon/daemon.c:282 [error] - Resource leak: random_access
* ./raster/r.li/r.li.daemon/daemon.c:708 [error] - Memory leak: file_buf
* ./raster/r.li/r.li.daemon/worker.c:259 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.daemon/worker.c:262 [error] - Memory leak: buf
* ./raster/r.li/r.li.dominance/dominance.c:159 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.dominance/dominance.c:370 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.dominance/dominance.c:574 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.edgedensity/edgedensity.c:164 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.edgedensity/edgedensity.c:427 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.edgedensity/edgedensity.c:692 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.mpa/mpa.c:137 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.mpa/mpa.c:200 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.mpa/mpa.c:265 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.mps/mps.c:159 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.mps/mps.c:530 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.mps/mps.c:900 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padcv/padcv.c:138 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padcv/padcv.c:535 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padcv/padcv.c:928 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padrange/padrange.c:146 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padrange/padrange.c:547 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padrange/padrange.c:930 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padsd/padsd.c:137 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padsd/padsd.c:536 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.padsd/padsd.c:927 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.patchdensity/main.c:204 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.patchdensity/main.c:205 [error] - Memory leak: mask_buf
* ./raster/r.li/r.li.patchnum/main.c:180 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.patchnum/main.c:181 [error] - Memory leak: mask_buf
* ./raster/r.li/r.li.richness/richness.c:145 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.richness/richness.c:303 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.richness/richness.c:465 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.shannon/shannon.c:155 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.shannon/shannon.c:362 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.shannon/shannon.c:565 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.shape/main.c:85 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.shape/main.c:85 [error] - Memory leak: mask_buf
* ./raster/r.li/r.li.simpson/simpson.c:154 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.simpson/simpson.c:343 [error] - Resource leak: mask_fd
* ./raster/r.li/r.li.simpson/simpson.c:532 [error] - Resource leak: mask_fd
* ./raster/r.mfilter.fp/getfilt.c:162 [error] - Resource leak: fd
* ./raster/r.mfilter/getfilt.c:160 [error] - Resource leak: fd
* ./raster/r.out.gridatb/file_io.c:105 [error] - Resource leak: fp
* ./raster/r.quant/read_rules.c:85 [error] - Buffer access out-of-bounds: buf
* ./raster/r.statistics/o_distrib.c:70 [error] - Resource leak: fd1
* ./raster/r.support/modcolr/modcolr.c:44 [error] - Dangerous usage of 'name' (strncpy doesn't always 0-terminate it)
* ./raster/r.support/modhist/modhist.c:45 [error] - Dangerous usage of 'name' (strncpy doesn't always 0-terminate it)
* ./raster/r.terraflow/nodata.h:65 [error] - Buffer access out-of-bounds
* ./raster/r.terraflow/plateau.h:50 [error] - Buffer access out-of-bounds
* ./raster/r.terraflow/unionFind.h:127 [error] - Common realloc mistake: "parent" nulled but not freed upon failure
* ./raster/r.terraflow/unionFind.h:131 [error] - Common realloc mistake: "rank" nulled but not freed upon failure
* ./raster/r.terraflow/stats.cc:80 [error] - Resource leak: fd
* ./raster/r.terraflow/sweep.cc:158 [error] - Uninitialized variable: flowpq
* ./raster3d/r3.in.v5d/v5d.c:2001 [error] - Resource leak: fd
* ./raster3d/r3.in.v5d/v5d.c:2381 [error] - Resource leak: fd
* ./raster3d/r3.out.v5d/v5d.c:2001 [error] - Resource leak: fd
* ./raster3d/r3.out.v5d/v5d.c:2381 [error] - Resource leak: fd
* ./raster3d/r3.showdspf/new_init_graphics.c:234 [error] - Resource leak: fp
* ./raster3d/r3.stats/main.c:665 [error] - Possible null pointer dereference: eqvals - otherwise it is redundant to check if eqvals is null at line 672
* ./raster3d/r3.stats/main.c:668 [error] - Possible null pointer dereference: eqvals - otherwise it is redundant to check if eqvals is null at line 672
* ./vector/v.clean/test/topocheck.c:54 [error] - Invalid number of character (() when these macros are defined: ''.
* ./vector/v.delaunay2/geometry.c:254 [error] - Uninitialized variable: v_n_o_b
* ./vector/v.delaunay2/geometry.c:255 [error] - Uninitialized variable: v_n_d_b
* ./vector/v.delaunay2/geometry.c:257 [error] - Uninitialized variable: v_n_o_b
* ./vector/v.delaunay2/geometry.c:257 [error] - Uninitialized variable: v_n_d_b
* ./vector/v.delaunay2/geometry.c:291 [error] - Uninitialized variable: v_p_o_b
* ./vector/v.delaunay2/geometry.c:292 [error] - Uninitialized variable: v_p_d_b
* ./vector/v.delaunay2/geometry.c:294 [error] - Uninitialized variable: v_p_o_b
* ./vector/v.delaunay2/geometry.c:294 [error] - Uninitialized variable: v_p_d_b
* ./vector/v.digit/i_face.c:91 [error] - Undefined behaviour: val is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./vector/v.digit/i_face.c:93 [error] - Undefined behaviour: val is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./vector/v.external/main.c:53 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./vector/v.external/main.c:55 [error] - Undefined behaviour: buf is used wrong in call to sprintf or snprintf. Quote: If copying takes place between objects that overlap as a result of a call to sprintf() or snprintf(), the results are undefined.
* ./vector/v.in.dwg/entity.c:516 [error] - Array 'tempdouble[2]' index 2 out of bounds
* ./vector/v.in.dwg/entity.c:517 [error] - Array 'tempwidth[2]' index 2 out of bounds
* ./vector/v.in.dwg/main.c:219 [error] - Invalid number of character (() when these macros are defined: ''.
* ./vector/v.label.sa/labels.c:131 [error] - Common realloc mistake: "labels" nulled but not freed upon failure
* ./vector/v.mapcalc/list.c:524 [error] - Possible null pointer dereference: item
* ./vector/v.mapcalc/list.c:525 [error] - Possible null pointer dereference: item
* ./vector/v.mapcalc/vector.c:127 [error] - Passing value -1 to sqrt() leads to undefined result
* ./visualization/nviz/src/togl.c:3548 [error] - Memory leak: pixels
also that tool gives a list a possible bashisms, but I've just
gone through those for devbr6, nothing of major concern there.
Hello Hamish,
Yesterday I was thinking about such tool, as I was fixing
v.digit/i_face.c (from Your list) (r44984). You are reading my mind
(that's scary).
I would like to call all sprintf() abuses (and probably all other
non-memleaks) a blocker and delay RC2 till all of them are fixed.
v.digit functionality was allready broken due to this and it also
could explain some others hard to catch bugs.
Sill most likely I will have no time till 20. Jan. to do any fixing.
inbuf
args
leak: fd
leak: fd
pszBasename
bounds
bounds
bounds
bounds
bounds
random_access
mask_fd
mask_fd
mask_fd
mask_fd
leak: mask_fd
leak: mask_fd
leak: mask_fd
mask_fd
mask_fd
mask_fd
mask_fd
mask_buf
mask_fd
mask_fd
mask_fd
mask_fd
mask_fd
mask_fd
mask_fd
mask_fd
mask_fd
mask_fd
out-of-bounds: buf
out-of-bounds
flowpq
leak: fp
at line 672
at line 672
v_n_o_b
v_n_d_b
v_n_o_b
v_n_d_b
v_p_o_b
v_p_d_b
v_p_o_b
v_p_d_b
out of bounds
out of bounds
dereference: item
dereference: item
This is a fairly common idiom in GRASS. As the tool notes, the
behaviour of using the destination buffer as an argument is undefined.
This specific case is easy enough to fix; just generate the entire
string in one go. In cases where the append is conditional, safe
alternatives include using buf+strlen(buf) as the destination and
sprintf()ing into a temporary buffer then appending that with
strcat().
