[GRASS-dev] crash in most recent wxgrass?
Martin,
I just updated and recompiled both GRASS 6.3 cvs and wxgrass. When I went to start up wxgrass, it crashed with the error below. I wonder if you have any thoughts as to what is causing this?
Thanks
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
========= wxpython error output =============
GRASS 6.3.cvs (spearfish60_test):~ > wxgrass&
[2] 13248
[1] Done wxgrass
GRASS 6.3.cvs (spearfish60_test):~ > Digitization tool is disabled.
Under development…
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/wxgui.py”, line 918, in
app = GMApp(0)
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/wx-2.8-mac-ansi/wx/_core.py”, line 7757, in init
self._BootstrapApp()
File “/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/wx-2.8-mac-ansi/wx/_core.py”, line 7354, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/wxgui.py”, line 900, in OnInit
mainframe = GMFrame(parent=None, id=wx.ID_ANY, title=“”)
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/wxgui.py”, line 188, in init
self.NewDisplay()
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/wxgui.py”, line 582, in NewDisplay
auimgr=self._auimgr)
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/wxgui_utils.py”, line 133, in init
Map=self.Map, auimgr=self.auimgr)
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/mapdisp.py”, line 1511, in init
self.MapWindow = BufferedWindow(self, id = wx.ID_ANY, Map=self.Map, tree=self.tree)
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/mapdisp.py”, line 216, in init
self.Map.SetRegion() # make sure that extents are updated at init
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/render.py”, line 402, in SetRegion
self.__adjustRegion()
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/render.py”, line 348, in __adjustRegion
(self.region[‘e’] - self.region[‘w’]) / self.width
ZeroDivisionError: float division
  File
"/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/ren
der.py", line 348, in __adjustRegion
    (self.region['e'] - self.region['w']) / self.width
Clearly, self.width is zero.
Maybe this code is being called before the widget has been fully
initialised?
Self.width should be the canvas width and should not be 0.
Michael
  File
initialised?
phone: 480-965-6213
fax: 480-965-7671
