On Wed, Jul 29, 2015 at 4:33 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Hi devs,
a colleague of mine has problem creating new location on Windows7.
Here the error that she got using epsg code or prj file
File "C:\Program Files (x86)\GRASS GIS 7.0.1RC1\gui\wxpython\gis_set.py", line
500, in OnWizard
grassdatabase = self.tgisdbase.GetValue())
File "C:\Program Files (x86)\GRASS GIS 7.0.1RC1\gui\wxpython\location_wizard\w
izard.py", line 1916, in __init__
msg = self.OnWizFinished()
izard.py", line 2111, in OnWizFinished
**addl_opts)
File "C:\Program Files (x86)\GRASS GIS 7.0.1RC1\etc\python\grass\script\core.p
y", line 1396, in create_location
encoding='utf-8', mode='w')
... mhh, once again an encoding issue?
File "C:\Program Files (x86)\GRASS GIS 7.0.1RC1\Python27\lib\codecs.py", line
881, in open
file = __builtin__.open(filename, mode, buffering)
IOError: [Errno 2] No such file or directory: u'D:\\GEOGRAPHY\\MODIS\\PERMANENT\
\MYNAME'
I wonder why there are double \\ while two lines above there are only
the common single \.
Just guessing...
D:\\GEOGRAPHY\\ exists and MODIS should be the location.
Hi devs,
500, in OnWizard
**addl_opts)
I don't think is an encoding problem...
881, in open
\MYNAME'
if it used os.path.normpath it add double \
Just guessing...
Is D:\\GEOGRAPHY\\MODIS\\PERMANENT\ there?
no, it should be created by the location wizard...
