I am trying to create a single hexagon raster mask. The only possible
way, currently, seems to be `v.mkgrid -h`, and then a rasterisation.
Using `v.mkgrid -h map=hexagon grid=1,1 --o`, I always get the "ERROR:
Please use a higher resolution or a larger region".
I have tried to do as the message recommends, but it does not work. Not
when increasing the resolution, nor when increasing the region.
I checked the code that tests for this in `main.c`:
if (grid_info.east - grid_info.west < 3.5 * grid_info.crad) {
G_fatal_error(_("Please use a higher resolution or a larger region"));
if (grid_info.north - grid_info.south < 3 * grid_info.rstep) {
I guess it takes some time to understand the reasoning behind these
tests. Is it really not possible to create a single hexagon, that
touches upon the edges of the computational region?
Nikos
