[GRASS-dev] Creating location from file problem
together with Helena I tried to create new location from a file,
it fails if a datum should be asked:
1. Create new location from a file -
I put the file at:
http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat/gdc.zip
When selecting the SHAPE file, the procedure in
lib/init/file_option.tcl
calls g.proj. In this case, it wants to query the user for the
datum, but for that it has to be run in the xterm wrapper which
isn't the case yet.
I tried
diff -u -r1.5 file_option.tcl
--- file_option.tcl 19 Oct 2006 12:03:48 -0000 1.5
+++ file_option.tcl 20 Oct 2006 08:45:28 -0000
@@ -114,8 +114,7 @@
                        if {[file exists $filepath]== 1} {
                                if {[file exists $thelocation ]==0} {
                                        destroy .fileloc;
- exec -- g.proj -c georef=$filepath location=$fileLocation >@stdout 2>@stderr;
- destroy .fileloc
+ exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e g.proj -c georef=$filepath location=$fileLocation;
                                        DialogGen .wrnDlg [G_msg "WARNING: restart GRASS please"] warning \
                                        [G_msg "WARNING: Please restart GRASS in order find the created location in the list (closing it for you now)"] \
                                                0 OK;
but the xterm window only flashes, then closes.
How to do it right?
> I put the file at:
isn't the case yet.
I tried
@@ -114,8 +114,7 @@
                                        destroy .fileloc;
- destroy .fileloc
                                                0 OK;
How to do it right?
1. Any GRASS program run in an xterm needs to use grass-run.sh, e.g.:
exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e $env(GISBASE)/etc/grass-run.sh g.proj ...
You should probably also use "-T g.proj -n g.proj" to set the title
back (otherwise it will be "grass-run.sh", which isn't particularly
informative).
2. Those semicolons shouldn't be there; I don't know if they will have
any adverse effect, but they are unnecessary.
3. The xterm will close as soon as the command completes (whether it
succeeds or fails). You can use the -hold switch to retain the xterm
window after the command completes, but you should only do that for
debugging; having to manually close the xterm window each time would
be annoying in normal use. Alternatively, redirect stdout/stderr to a
file, to catch any error messages.
> > I put the file at:
> isn't the case yet.
> I tried
> @@ -114,8 +114,7 @@
> destroy .fileloc;
> - destroy .fileloc
> 0 OK;
> How to do it right?
informative).
Very nice, it now works and is fixed in 6.3 and 6.2-release branch.
Thanks for the quick help!
Here is another problem that we have found for starting a new location and it applies
to g.setproj and the creation of new location from projection values:
when I enter stp (State Plane) for projection it gives an ERROR that says that stp is
not specified in the table (although it is listed and it used to work and in lib/gis/projections it is defined.)
Was this removed? It used to ask for datum and FIPS codes. It is one of the most common projections
in US so it would be good to put it back. It works in GRASS61 from february
Thanks Helena
concerning the State Plane (STP) problem, here the error message:
g.setproj
Please specify projection name
Enter 'list' for the list of available projections
Hit RETURN to cancel request
stp
ERROR: Projection stp is not specified in the table
Using a debugger, I found that (the new)
$GISBASE/etc/proj-parms.table
is analyzed by get_proj_parms() in lib/proj.c. Since STP
isn't listed there, it fails with
        if (!proj_parms)
            G_fatal_error("Projection %s is not specified in the table", proj_out);
The parameters to query for STP are
- geodetic datum (e.g. nad27)
- State FIPS
- County FIPS for selected state
- State Plane 1927 or 1983
- units (US survey Foot, Int. Foot, meter)
I don't know how to add that in $GISBASE/etc/proj-parms.table
nor if and why STP disappeared from GRASS 6.2/6.3.
The code seems to be in general/g.setproj/get_stp.c .
It seems that it just exits too early in general/g.setproj/main.c .
february
Thanks Helena
grass-dev mailing list
grass-dev@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
This problem occurs also with Lat-Long (LL), so I had to create a new
location with "g.proj -c". When "grass -text" creates a new LL
location, it says that the user needs to run g.setproj to properly use
any projection related modules, but it fails because LL is missing from
proj-parms.table. This is certainly not a good experience for new
users.
Huidae
On Sat, Oct 21, 2006 at 01:47:10PM +0200, Markus Neteler wrote:
g.setproj
>stp
        if (!proj_parms)
- State FIPS
> february
> Thanks Helena
I *think* that I have fixed it (applied to CVS):
Index: proj-parms.table
RCS file: /grassrepository/grass6/general/g.setproj/proj-parms.table,v
retrieving revision 2.1
diff -u -r2.1 proj-parms.table
--- proj-parms.table 1 Oct 2006 21:18:05 -0000 2.1
+++ proj-parms.table 22 Oct 2006 08:19:18 -0000
@@ -48,6 +48,7 @@
LCC:LAT0=ask,23.0;LAT1=ask,33.0;LAT2=ask,45.0;LON0=ask,-96.0;X0=ask,0.0;Y0=ask,0.0
LEAC:LAT0=ask,55.0;LAT1=ask,0.0;LON0=ask,20.0;SOUTH=ask,nodfl
LEE_OS:LAT0=noask,-10.0;LON0=noask,-165.0
+LL:LAT0=noask,0.0;LON0=noask,0.0
LOXIM:LAT0=ask,0.0;LAT1=ask,45.0;LON0=ask,20.0
LSAT:LAT0=ask,0.0;LON0=ask,20.0;SNUM=ask,1;SPATH=ask,1
MBTFPP:LAT0=ask,0.0;LON0=ask,20.0
@@ -91,6 +92,7 @@
SINU:LAT0=ask,0.0;LON0=ask,20.0
SOMERC:KFACT=noask,1.0;LAT0=noask,46.952405556;LON0=noask,7.4395833333;X0=noask,600000.0;Y0=noask,200000.0
STERE:KFACT=ask,1.0;LAT0=ask,0.0;LATTS=ask,0.0;LON0=ask,20.0
+STP:LAT0=noask,0.0;LON0=noask,0.0
TCC:LAT0=ask,0.0;LON0=ask,20.0
TCEA:KFACT=ask,1.0;LAT0=ask,0.0;LON0=ask,20.0
TISSOT:LAT0=ask,0.0;LAT1=ask,-30.0;LAT2=ask,45.0;LON0=ask,20.0
Please test it (STP and LL).
I have also 'indent'ed main.c of g.setproj. A few compiler warnings are
still there.
users.
Huidae
> Hi,
> g.setproj
> >stp
> if (!proj_parms)
> - State FIPS
> Markus
> > february
> > Thanks Helena
> > _______________________________________________
grass-run.sh does:
# run command
EXIT_VAL=$?
if [ $EXIT_VAL -ne 0 ] ; then
   echo -e "\r"
   echo "ERROR: $1 exited abnormally. Press <enter> to continue."
   read
fi
exit $EXIT_VAL
so it should pause on exit, and the #1 suggestion above should solve
more than one problem.
Hamish
are still there.
what other ones could be missing? (or another way, why were these two
missed?)
Hamish
> are still there.
I have compared to the GRASS 5 projection list: missing are
- krovak
- krovakgis
- vitk1
PROJ 4.5.x contains new support for krovak, so this could
be the occasion to re-introduce it in GRASS 6.
(or another way, why were these two missed?)
I dunno - maybe an oversight? Glynn will know more.
are still there.
- krovak
- krovakgis
- vitk1
Since proj 4.4.9 there is also support for alternative parameters for lcc (lcca) and stere (sterea) as separate projections, and for geos, Geostationary Satellite View.
Historical explanation: g.setproj originally only supported a few projections, (XY), LL, UTM, STP. The setup code for these was different from the projections added later. The old setup code for LL, UTM and STP was retained in order not to mess up working code while experimentally adding support for 118 additional projections supported by proj. Since STP already had working setup code it was not included in geo_init.c, the file containing parameters for the new projections. Thus, when Glynn converted geo_init.c to proj-parms.table he may have overlooked STP.
Morten
> > are still there.
- krovak
- krovakgis
- vitk1
The tables only included the projections which were already handled in
G_geo_init_table() (that was the source for the tables).
Those didn't occur in G_geo_init_table(), presumably because g.setproj
handled them as special cases. Actually, I'm surprised that UTM is in
there.
