[GRASS-dev] creating location from the command line
On 4/6/08 9:00 AM, "grass-dev-request@lists.osgeo.org"
<grass-dev-request@lists.osgeo.org> wrote:
Message: 2
Date: Sun, 06 Apr 2008 13:59:05 +0700
Subject: [GRASS-dev] creating location from the command line
To: grass-dev@lists.osgeo.org
Cc: Ivan Shmakov <oneingray@gmail.com>
Message-ID: <m2od8nii4m.fsf_-_@cherry.siamics.int>
Content-Type: text/plain; charset=us-ascii
Glynn Clements <glynn@gclements.plus.com> writes:
I tinkered with the grass.sh script in
/Apps.../Grass-6.3.app/Contents/MacOS to bypass any of the GUI setup
(X and Terminal windows) when GRASS_BATCH_JOB is non-empty. That
provided the behavior I was after and didn't interfere with
interactive use, so setting and acting upon a switch to indicate
background execution will work.
GRASS_BATCH_JOB is a bit of a hack. You would be better off
bypassing Init.sh altogether.
I wonder, is there a way to create locations non-interactively?
You can do this with g.proj.
This is how it's done in the wxPython location wizard. If interested, check
out the code there.
Michael
It may be quite useful in, e. g., the test suite's scripts.
I've in mind the following scheme:
* create a fresh location;
* prepare inputs and produce outputs;
* check checksums (SHA1 or MD5) of the files in the locations to
match those contained in the test suite; check for unwanted or
missing files as well;
* if all went good, remove the location; otherwise, leave it
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
