On Aug 24, 2006, at 3:57 AM, Hamish wrote:
On Sun, 6 Aug 2006 16:46:12 -0500
"Kirk R. Wythers" <kwythers@umn.edu> wrote:
However, the README file for it says that it was written for grass
5.4. Does anyone know if there are particular coding issue when
writing a module for 6.1 relative to 5.4?
the raster format is unchanged, so not (m)any issues to worry about.
Thanks very much Hamish,
I think my approach is going to have to be "baby steps". I did look at r.example (recommended by Markus), which seems to read in a raster, does nothing to it, then writes a new raster. If I want to write a ecosystem model module for GRASS, then my goal is to figure out how to organize my model's code into the "does nothing" portion of r.example.
If you don't mind, like to describe my models data requirements, and then hear your thoughts as module design.
The goal here is to write a module r.pnet. PnET is a general ecosystem model that does carbon, water and nitrogen balance. It can output things like gross and net primary production, net ecosystem production, plant and ecosystem respiration, etc.
In it's present form PnET requires a file of vegetation parameters, and a file of climate parameters (climate inputs are temporal, i.e. daily time step would have one day of temps, precipitation, and solar radiation per line). However, on a spatial application such as this, climate will vary both temporally and spatially, therefore I will need a multidimensional data holder for climate inputs.
Presently the vegetation parameters are in individual files based on cover type (for example, one file for oak, one file for maple, one file for pine, one file for corn, etc...
I am envisioning a GRASS module that takes a input raster of land cover, and for each pixel, gets the vegetation parameters associated with the land cover type, gets climate data for the current time step (that day for example), then runs the PnET model for that pixel, then writes it's output, before moving on to the next pixel.
Perhaps a good start would be to write some over simplified PnET code into the "does nothing" portion of r.example and see if I can get anything working?
Thanks again,
Kirk
